Question about Whirlpool LER4634J Electric Dryer
My dryer runs and tumbles but it wont heat up. What is the problem?
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Dryer heats but wont tumble/electric
Broken belt due to bad rollers or idler or simply rotten belt. GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 30, 2009 | Kenmore 63942 Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Just hooked up outlet. Dryer tumbles, wont heat. Have I wired the outlet wrong?
Hi, Did you put red and black wire to the outer posts? White wire ti center and green to ground screw on cabinet? Dry will run on 120V but needs 240V for heat. Make sure there is 240V to the outlet as well.
Hope this helps. If so, please feel free to rate my answer so that I know how I am doing.
Vic
May 10, 2009 | Dryers
Dryer wont dry but heats and tumbles. takes 3 cycles to dry
Have you checked the entire duct run. When dryer vents should feel like a hair dryer on high blowing outside
Feb 16, 2009 | Roper RES7646KQ Electric Dryer
Tumble dryer not heating
Hi irshaad,
If all the componants are good, you are loosing voltage somewhere. Check the voltage to the dryer. If you do not have 220 volts then you have a blown fuse or a kicked breaker in your fuse box. This would allow only 110 volts to get to the dryer and the dryer would run and not heat. If you have the correct voltage to the dryer check the connections on the terminal block and the wires to the block. Before going any further than that I would really rather have your model so I could guide you correctly. Good luck and I really hope this will FixYa.
Mike Anderson
May 25, 2008 | Dryers
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
