Question about HP OfficeJet 6110 All-In-One InkJet Printer
My hp officejet 6110xi all in one won't align ink cartridges
  • jimarney Jun 05, 2010
    thanks for your input, but I have installed new ink cartridges!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 127 Answers
The reason that it wont align is you are either out of black ink or the tricolor ink ctg needs to be replaced
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Posted on Jun 05, 2010
My hp officejet 6110xi all in one says remove and check cartridge but the ink is new
You have to disconnect power to the printer and also disconnect the printer serial or usb cord,
reconnect it, when it reboots, it will see the new cartridge and the error will go away. good luck!
Jul 12, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Press enter to align cartridges won't go away...what do i do? and don't say "press enter".
For these all-in-one devices this usually indicates that the sensors are so dirty they can't tell when the cartridges are in place and properly aligned. Sometimes, but not by any means all the time, replacing the cartridges with factory fresh (not knock-off) cartridges can get you past this issue but for the ones we have at the office, once the device starts doing this we tend to send them to asset recovery and get something newer.
You might check for paper dust inside the mechanism or ink smears, but these devices are notoriously hard to clean very well.
Oct 03, 2009 | HP OfficeJet 6110xi All-In-One Thermal...
My printer stopped printing
your senser is off you have to tak it in for minor repairs
May 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have a hp officejet 6110xi all in one
hI,
the Issues seems to be with the hardware malfunction and it is not only related to the cartridge.
However, you can perform the following steps and in case if the issue persists, you need to replace your printer.
Connect your printer directly to the wall outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord
Regards,
sagarjd
Nov 18, 2008 | HP OfficeJet 6110xi All-In-One Thermal...
I receive a consistent message that alignment of cartridges failed.
Ensure you are using original HP cartridges. Using refilled/generic inks can cause this problem.
If you are using original inks, try cleaning the contacts of the cartridges gently with isopropyl alcohol. Should it still fail, get them replaced.
The above solution was Comment by IrishDruid, posted on Jun 01, 2008. I tried it on my HP officeject 6110xi (using alcohol swabs). It worked perfectly.
Jul 10, 2008 | HP OfficeJet 6110xi All-In-One Thermal...
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01299067&cc=us&lc=en&dlc=en&product=79477
Here is the other web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01300415&cc=us&lc=en&dlc=en&product=79477
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP officejet 6110xi
Hi , the new installed are genuine ink ? If generic try to replace with original hp ink. the printer can detect if not genuine .
Feb 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
K60xi won"t align cartridges
what are going to do is just fix thee color ink cartridge of your printer......
Jan 26, 2008 | HP OfficeJet k60xi InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
281 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
