Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
M50wh72s Many problems for one the Ballast reads 340 v at all times even when TV is off. Two the lamp dose not come on. Three when the TV comes on thair is a high pitch sound going up then down. Four when TV goes off thair is a blue screen that fades out to black. Popping sound then no picture
  • 4,234 Answers
This one may take a while to completely diagnose, but from what you've described so far, I say the ballast is bad. The whine is the ballast trying to fire. The pop may be related. The ballast is available for $140 (you get back $30 when you return the bad one). I'd start there. The part number is: 271922.
Dan
Posted on Apr 09, 2008
    Genius:
  • 1,665 Answers
  • RCA Master
  • 19,396 Answers
You have far more than one problem could be time to call a service.
  • Ginko
    Ginko Apr 09, 2008
    With all this issues together the risk is that you fix one problem, and you get an additional one. For example the ballast reading 340v may means that you probably need to change power unit, the blue screen may be a problem with convergence ICs (check pico fuses) or crt board. Unless you have a good workshop at home it may be time to call service. Here is RCA contact, they can find a service in your area.
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
RCA M50WH72S Replaced bulb and ballast. TV comes on with good video for about 5 seconds, then off with good audio, front power light blinks 5 times. After a few minutes the video comes back on and repeats...
Check capacitors cp624, cp647 1000uf@35v each. They are in the power supply. Can be seen with bulge on the top. Seems to be a common problem with this model RCA.
Jun 07, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
My samsung hlr6167w will not power up. It sounds as though the lamp is trying to strike, however it never does come up on a picture. After several minutes, all three lights on the front power cirle (Lamp,...
All three LED lights flashes,u hear alot of clicking sounds too?Yes,ur tv the Ballast board is dead too.This Ballast board job is only to ignite the tv projection lamp only.Replace the Ballast board,should solve this problems.
Apr 17, 2011 | Samsung HL-R6167W 61" HDTV
I have a 2006 Thomson/RCA ModelM50WH72S TV that we have replaced the lamp, it still does not work and a technician has told us that we need a light engine for it. How can we locate one?
have the same tv,, power light blinks, book said it was bulb, bulb didnt fix it,took it to tv repair shop, they found a bad capacitor, replaced it with a higher heat range capacitor, this capacitor was on the power board for the lamp circuit, repair was $200, not bad since i paid $1500 for the tv, other than that issue, just replaced a couple of lamps
Dec 28, 2010 | Televison & Video
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Problem turning On
The lamp, ballast or dmd board can cause the same problem. Most commonly on these DLPs it is the lamp, but we have to use the process of elimination as well sometimes. Even as a samsung warranty center sometimes the flow charts don't help. The first thing I would do as a consumer is to vacuum around the ventilation holes behind set, these can cuase poor circulation and startup/shutduwn problems. Then with those type of lights flashing start by bidding for or buying the most inexpensive lamp you can get. Make sure exact replacement. Do not touch the glass on lamp when replacing. Then try the ballast which also has a part number on it and has only two screws when you have lamp removed from set. If still no luck, assume it is the dmd board and try pricing that baby. Not cheap! Then comes the decision. New set or repair this. This is what you can expect unfortunately. But I have the same set at home. Go figure.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
LED green and red light blink
the ballast should make momentary arcing sound and orange flash in its spark gap tube when it 1st trys to light the lamp. look for it in the darkness it will be easier to spot, as you listen for it. make sure you are buying toshiba factory replacement lamp.
Jan 14, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
M50wh72s
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Dec 21, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
182 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
