Question about Belkin F1DK102P 2-port KVM Switch
About the belkin 2 port kvm switch
I have a ? how do i hook this switch up to were i can run it off 2 computers can ya help me hook it up the right way ? please a friend let me have it so i wanting to try it out
  • dontknow1 Jul 07, 2008
    i connect this KVm switch up to two cvomputers and then when i go to turn them on. Nothing happens. My keyboard is flashing and my monitor wont turn on. What should i do. thank you?
I was having the same problem... I'm using a Belkin KVM (2 Port); model number unknown. But when you hit the scroll lock twice, you should notice the lights blinking on the KVM switch. If you do nothing else, the blinking stops, and nothing was switched. Apparently, in my case, I had to double click the "scroll lock", then click the up and down arrow keys to select which computer to use (you will now see the light switching on the kvm switch. Hope that helps others..
PJM
Posted on Apr 03, 2009
I already have one computer hooked up to a beklin. can i hook up another
Posted on Feb 19, 2009
With the 2-port KVM Switch I have, keyboard flashing means it will keep switching between ports every 4 seconds. You need to hit ESC once to stop it.
Double-tap Scroll Lock to enter switching mode, and hit ESC when the desired port is displayed.
To get it working at all, shut down all the systems you want to hook up with the switch, hook them up (and you need to hook it to Keyboard as well) and then boot.
Posted on Sep 03, 2008
Screen resolution keeps switching
If its a usb kvm, check usb connections, one computer should stay fixed, the one that doesn't is your problem
Nov 21, 2011 | Belkin F1DF102PEA 2-port KVM Switch
How do I switch between computers using old Belkin 2-port KVM?
if i remember right, hitting the scroll lock key twice, and then pressing 1 or 2, depending on which box is your xp box.
hope this helps
Feb 16, 2010 | Belkin F1DK102P 2-port KVM Switch
I have a usb 2 port belkin switch to use one printer with 2 computers it was working fine now it switches over but it wount print from one of the computers. what could it be?
If available usb cables permit, hook up printer directly to the computer that does not print to check to see if software or connection is a problem rather than the belkin switch
Chris
Dec 30, 2009 | Belkin F1DF102PEA 2-port KVM Switch
Where can I can the drivers for the Belkin 2 port KVM switch F1dk102u
Hi:
The Belkin 2 port KVM switch doesn't need drivers to work, it is simply a plug and play switch. You plug your keyboard, mouse and monitor into the control box, and your computers into the ends, and off you go. You toggle between computers with the switch button, and if you turn off one of the computers, it automatically swiches to the other one.
Nov 11, 2009 | Belkin F1DK102U 2-port KVM Switch
How do I hook up a Belkin 2-way Switch with Audio Support and Cabling?
kvm switches are easy, they just dont look it with the number of sockets.
hook up your keyboard monitor speaker mic mouse cables to the output sextion of the kvm just as if you were hooking them to a single pc.
hook the cables from the pc-s as if the kvm switch were the peripheral devices,
so that all the outputs from pc 'A' are connected to the relevant inputs on 'A' side of the kvm,
all the outputs from pc 'B' are connected to the relevant inputs on 'B' side of the kvm
Jun 26, 2008 | Belkin F1DL102P 2-port KVM Switch
Belkin 2-port kvm switch
mcdevito75 here, You can try to contact Belkin itself, but with-in the 2 years you had wireless, many more users of different computers, and satalites that the wireless needs have also changed.
Jun 01, 2008 | Belkin F1DK102P 2-port KVM Switch
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
If you have the PS2 mouse and keyboard (round plug-in) instead of USB this is an easy install. however if you have USB you will need adapters to make this work, but I do not recommend it since more problems could occur. If you have the PS2 ends first shutdown both computers. remove your monitor, mouse, and keyboard from your computer and attach them to the single end of the switch. Mouse goes to Green, Keyboard to Purple. Take the other ends and connect the first group to your first computer mouse, keyboard, and monitor (same colors as above) and repeat for 2nd group of wires on 2nd computer. turn the computers on. you should get display, keyboard, and mouse for 1st computer. after both boot hit scroll lock 2 times within 2 seconds and then arrow up or down key to change between computers.
Oct 18, 2007 | Belkin F1DK102P 2-port KVM Switch
KVM switch mouse trouble
Does a mouse work if plugged directly into the laptop? Sometimes you have to change a laptop in the BIOS to allow a PS2 mouse in addition or instead of the touchpad. It may not be recognizing the KVM as a mouse. Try plugging the mouse right into the laptop and see if that works.
Mar 24, 2007 | Belkin F1DK102P 2-port KVM Switch
Belkin F1DK102P 2-port KVM Switch Logo
915 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
