Question about KitchenAid Dishwashers
Dishwasher does not seem to have power. I have a Kitchen Aid, under counter unit, 9 years old, model KUDS01I. I used it 2 nights ago with no problem. When I push a button, nothing happens, no lights show, etc. It is plugged into the lower half of a duplex socket with disposal plugged into the top. Disposal works, so the problem seems to be with the dishwasher. That also eliminates any issues related to breakers or ground fault indicators, etc. Is there a reset button on the dishwasher? Is there a part that could overload and need replacing?
    Habit-Forming:
    New Friend:
  • 34 Answers
First try to unplug and then plug it back in. Hopefully this will reset the dishwasher. Good luck.
Posted on Sep 26, 2017
jsrock516
  • 5911 Answers
SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Posted on Apr 08, 2008
  • 1073 Answers
SOURCE: kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
Posted on May 03, 2008
SOURCE: dishwasher/garbage disposal problem
You probably forgot to knock out the plug in the disposer for the dishwasher.
Posted on Nov 07, 2008
Loringh
  • 185 Answers
SOURCE: garbage disposal (water won't drain out of sink standing water)
There should be an overload button somewhere on the bottom of the disposal motor. This is to prevent the motor from trying to run if the chopping blades are jammed, otherwise the motor would burn up.
First, try to move the blades with something like a broom handle. Using a flashlight you should be able to see the blades. there's probably three of them. try to make sure each one can move even a little bit.
Next, with the disposal switch in the off position, find the overload button and push it in, Then turn on the disposal switch and see if it runs. If the overload button trips off again, repeat the above steps until the blades can turn.
Let me know how this goes. Loringh
Posted on Nov 08, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
I have a Kitchen Aid 2 drawer dishwasher and its about 2 years old. My problem is the top drawer will not drain during wash cycle. The bottom drawer drains fine. model number KUDD03DTSS 10
You may have clogged pump to the drawer. open drawer, lay on your back under the dish drawer, removed the black cover (3 screws) remove 2 screws to the pump and allow the water to drain out into a bucket or bowl. make sure the pump can turn easy. Reassemble and test unit again. If fails, replace pump.
Pump
I hope this helps, good luck
Aug 14, 2011 | Dishwashers
Leaves a white soap residue over the dishes, the dishes are scratched. New Kitchen Aid model KUDS50FVSS4 just purchased one month ago and it's performance was not as good as my old ( 15 years) GE. I have...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101;'
Apr 25, 2011 | KitchenAid KUDS50FVSS Builtin Dishwasher
Water not flowing from Kitchen Aid Refrigerator. I've switched the filter and it has not resolved the problem. the unit is one year old, was working properly. 2 days ago, water leaked from spout and that...
water maybe frozen somewhere in the system. may need to disconnect water connections at various points and retry to narrow down where freeze up is at.
Jan 06, 2010 | KitchenAid Refrigerators
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Control panel cover falling apart
i looke dup your model and you seem to have the hidden control panel model. the manufacture is funny htat way they will only cover part if you have installedby auth servicer, i looked up the part for you part number 8531269 retails for about $70. its the enitre console assy including overlay. so although they cover it youd be better off buying it direct and installing your self for sure. simple enough repair, the screws (torx15) from the inner door panel come off and release the panel, everthing on the inside simply unsnaps and gets transferred to the new part. just remember to disconnect power first all live wires!
Nov 06, 2008 | Dishwashers
Whirpool quiet partner dishwasher seems to have no power
Ok there is a thermal fuse mounted on the control board that shuts down when it gets too hot. Did you run a sanitize cycle? Even if customers dont use the sani cycle which i recommend the fuse may open due to poor wire connections. The new fuse kit comes with a new harness and new connectors. Check the old fuse to be sure its bad. Dont remove the connectors from the new switch at all - dont disturb them and they will work better.
Dec 02, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Dishwashers Logo
93 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
