Question about RCA R56WH76 Projection Television
The picture is messed up, looks like the colors are seperating, not sure if the color is going out or if its the picture.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 05, 2010
Colors seperate
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
Jun 05, 2010 | Sony KP-46WT500 46" Rear Projection...
The picture shows all 3 colors seperate from each
Sounds like a problem in your convergence circuit. This is the circuit responsible for making sure all 3 colors align perfectly so that you don't see what you are seeing now. If you have tried adjusting it and that did not work then you will need to have the convergence circuit repaired.
May 24, 2010 | RCA R52WM24 52" HDTV Projection Television
Picture is a mess words look like looking through a coke a bottle bottom, with a curve to the whole picture colors are seperating
This is a convergence issue this will need to be repaired its is common with age and can be repaired you looking aroung $50 bucks to have this done Tv needs to be opened up there is little pieces of magnet type substance that helps with convergence on the back of the tube this will need to be evaled and replaced.
Thanks and please leave postive ratings and feedback for your free answer today!
Nov 19, 2009 | Office Equipment & Supplies
Pink and green colors seperated images rounded off
If colors are skewed and will not adjust in the customer menu---you have a CONVERGENCE circuit problem.
This model (KP-51WS500) uses two of the STK-392-560 convergence IC chips. I just got home from fixing a similar model with the same problem.
Parts cost on Ebay for the chips and such is going to be less than 30 dollars total. Shops are going to get 300 or more for this kind of repair---and some will not do it in your home---the repair takes about an hour--I have done hundreds of them here in people's homes.
If you have questions or need advice, reply to this posting and I will try to help.
If this told you something that helped you understand, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Sony KP-51WS500 51" Rear Projection...
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Toshiba TP55H60 55" Rear Projection...
Colors seperate and picture bent
THIS is a convergens problum .pls. prees menu key and see convergence menu select and see cross line on center the screen select one by one colour line to meching and cross line is white see the pictur is ok.
Oct 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The colors are out of wack.
THIS IS CAUSED BY A MAGNET IN THE SPEAKER OR SEPERATES SPEAKERS AROUND TV U WILL NEED TO GET IT DEGOUSED BY TV ENGINEER U MAY HAVE TO HAVE A SMALL THERMISTER CHANGED/BY ENGINEER
SOMETIMES LEAVE SET OF FOR A WHILE AND SWITCH ON AGAIN SOMETIMES USED TO WORK
MOVE SPEAKERS FROM SET
Aug 28, 2009 | Televison & Video
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Picture mess-up
This is a convergence problem that can be either bad connections on the convergence ICs or defetive ICs. If you can solder you should be able to fix this yourself. Look for large black ICs attached to a heat sink that will likely be marked STKxxx. Resolder the pins on these first. If that fails to resolve the problem, replace them. Expect to pay about $20-$35 for each one. There should be 2 of them.
Dan
Jun 02, 2008 | RCA HD52W58 52" TV
Open Questions:
RCA R56WH76 Projection Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
