Question about Amcor PLM-14000E Portable Air Conditioner
Hose overheats...where can i get insulation for it and what type of insulation should i use?
  • 146 Answers
You can use flex from home depot but i recommend foil flex
Posted on Jun 05, 2010
Testimonial: "Thanks...I'll get the foil flex."
Upper hose hot lower hose cold has good heat in car not overheating runs fine just lower hose not hot even after tstat opens
The lower hose shouldn't be as hot as the top. If your not having overheat problems I wouldn't worry about it. If the radiator was clogged, it would overheat.
Feb 07, 2015 | Cars & Trucks
Why is my car overheating?
Sounds like a stuck closed thermostat. It is usually where the top hose connects to the engine block.
Aug 16, 2014 | 2003 Jaguar X-Type
Keeps overheating plug
Plug will only overheat if you have a loose connection of some type.
Check the connections in the plug - the wires must be tightly connected to the pins and must not be screwed down onto the cable insulation. Check the fuse carrier in the plug - make sure it holds both ends of the fuse securely. Also check the fuse carrier components are securely fixed (usually with a screw or a rivet) to the pins of the plug.
If it still overheats the bad connection could be due to a bad wiring connection to the socket it is plugged into or even a bad component within the socket itself. Components in the socket are not repairable - Replace with new.
Aug 29, 2012 | Hotpoint WMA44 Front Load Washer
Cooling system
For car running hot and overheating issues, I suggest to you go through this help links.
Click this link below and go through the troubleshooting procedure to take care of the problems: ----
Car runs hot?
http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?
http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
overheating?
http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 14, 2012 | 1996 Toyota Avalon
Where is the heater fan switch located
For car running hot and overheating issues,i suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems :----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
Car freeze overnight and started overheating while driving? http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping? http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Feb 11, 2012 | 1999 Saturn SL
Kia spectra 2000, what causes over heating?
Hi and welcome to FixYa!
Few things why the car overheats, here are the following:
- Weak radiator blower motor
- Clogged radiator
- Cracked head or head gasket
- Faulty water pump (coolant will not circulate if it's faulty)
- Worn out radiator hoses
- Coolant reservoir overfill (coolant overflows)
You will need to have them replaced to resolve the problem. Hope this helps and thank you for using FixYa! Have a good one!
Feb 21, 2011 | Kia Spectra Cars & Trucks
The sheetrock around the exhaust vent gets wet when running my Kenmore dryer. what causes this and what is required to fix it? The exhaust vent is located at the bottom of the dryer and goes through the...
This is steam moisture from the drying of your clothes. Check for a loose fit with your drier hose and the vent connection. You can try a refrigeration tape if needed. Also you can cover the hose with insulation, look for a metal film type.
Feb 27, 2010 | Dryers
I want to insulate the computer panel on my 2003 saturn ion to keep from freezing over night. Can someone tell me where it is on the car?
DO NOT insulate your computer,,,you will overheat it and ruin a very expensive computer,they are made to with stand these conditions,DO NOT insulate it
Oct 19, 2009 | 2003 Saturn ION
The Newair acp 1400h puts out a lot of heat and the manual says not to extend the exhaust hose. Is there any way to extend the hose so that I can exhaust where I want to?
The longer hose will increase the heat in the room and that is why they recommend the short hose…addition to that it may overheat…if you are going to extend the hose you must use one as the dryer hose that insulated and fire proof…let me know if that help
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Sep 17, 2009 | NewAir ACP-1400H Portable Air Conditioner
Amcor PLM-14000E Portable Air Conditioner Logo
203 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
