Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
TOP FRIZER WORKS BUT REFRIGERATER SECTION DOES NOT WORK
  • 53 Answers
This sounds like either a defrost problem or a evaporator fan problem. Listen for the fan in the freezer to see if it is operating. If it is a defrost problem the back of the freezer will usually be covered with frost. What is the model number of the fridge and i can help you further.
Posted on Jun 18, 2010
My refrigerater is still iceing up ,in the freezer part,causeing the refrigerater too be warm ,and i have already changed the heater and the thermostat.
if you have a full freezer and a not so full fridge a brand new one will do that but check your door seals as well
Apr 23, 2012 | Refrigerators
My whirlpool refrigerater is not cooling properly, the freezer is working but the fan in back turns freely by hand but I haven't seen it actually start by itself
replace fan motor. same thing happened to me but I can't see other end of fan wires.I will have to cut and solder wires for new fan...I have question on how to get that darn relay box off compressor to see where condenser fan wires go!!!
Jan 28, 2012 | Amana ATB1832AR Top Freezer Refrigerator
No water is coming out of the water depenseron the refrigerater
does your ice maker work OK ? if yes , do you have a inline water filter in the upper right hand section of your refrigerator at the rear ? if yes , replace the filter and follow the directions on the new filter to properly prime the water dispenser line. if the unit will not prime with the new filter installed, you'll probably have to replace the water dispenser control valve located at the bottom rear of the refrigerator where the main supply water line goes into the refrigerator.
Mar 17, 2010 | Refrigerators
Refrigerater want cool
it sounds like you have a defrost problem first you need to find the defrost timer and advance it into defrost then take the back section of the freezer apart check to see if the heater is glowing if it is you need a new timer if not you need to unplug the ref take the wires off of the heater and with an ohm meter check to see if you have continuity if not you need heaters if it does have continuity you will need to replace the defrost terminator located somewhere on the evaporator usually located either top left or top right
Aug 28, 2009 | Refrigerators
Refrigerater is not cooling
The refrigerator gets air from the freezer. Look in the freezer for frost. If you have frost in the back or bottom the you have a defrost problem. Could be a timer or heater that is bad. If no frost do you hear a fan? You should have a evaporator fan running. Maybe thats out and it not circulating air for the refrigerator. You can check this out.
Hope it helps
Aug 17, 2009 | Whirlpool Refrigerators
My GE refrigerator is not working
in the refrigeration section there is a fan assy and damper assy, theis assy is really one kit and needs to be replaced.
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
My freezer and refrigerater will not get cold
u would have a leak in your sealed system if the fan and compressor are working and still not cold very expensive to fix
Mar 18, 2009 | Frigidaire FRT21H8 Top Freezer...
My frizer has a air leak in the top corner of the door
If it is only at the top, it is no big problem. I use foam tape available at any hardware store, or even Wallmart. Just trim to fit.
Apr 22, 2008 | Refrigerators
Akai frizer
on the top of the motor there is a plastic cover which contains a thermal button,try to hit it in this spot and if it works you might change it with another
Nov 18, 2007 | Freezers
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
217 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
