Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Fridge section not cold
The model rs 735
the frezer side works not the fridge
  • Samsung Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorfridge section not cold - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 05, 2010
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
Frezzer works but not refrigerator refer section does not get cold but frezer section works
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
There is frost buildup on back wall of frezer fridge or frezer dont get cold enough
my fan blade had slipped down and was rubbing makeing a noise and fine particles of white dust was at the rub point. Pushed the fan back up drop of super glue and lubricated the motor. works great!
Jul 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Model rs21dcsv freeze is working but fridge is not working
CHeck to see if there is ice built up on the back wall of the freezer. If so you have a defrost problem. Manually defrost it then take the back wall out of the frezer and check ohms on the heater if heater is ok then replace just the defrost timer and thermostat. If heater is bad replace all three.
Nov 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
I have a Kenmore side by side fridge
check the freezer compartment at the back wall. see if there is frost build up at the back.
sounds like a fosted evaporator to me.
check also the evaporator fan in the freezer section if it is running.
if not, then there is your problem.
tnx 4 using fixya,
drcool
Nov 04, 2008 | Kenmore Refrigerators
Kenmore side by side not getting cold
check the condenser motor at back of unit if is not running it will get hot in the middle section and it wil not cool properly
Aug 06, 2008 | Kenmore 50522 / 50524 Side by Side...
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
154 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
