Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Impact not working correctly
I have two dewalt impacts and they both are doing the same thing I start to put in a screw and it starts to go in then it stops but motor is still running but the front where screw is not moving why is it doing that ? I have dc825 and dw056
The pinion on front of motor is slipping on motor shaft. It seems to be just a press fit. Seems like a flaw in design. I had same problem. I took the dw056 apart and took pinion off motor and pressed groves into motor shaft with side cutter pliers. then pounded pinion back onto motor shaft. We will see how long this lasts the motor shaft is a softer metal. I feel the motor shaft should be hardened steel like the pinion and have a shear pin or some sort of spline to attach to pinion. Would like Dewalt to offer fix for this as I only used dw056 a couple of times before I had problem.
Posted on Jul 31, 2010
  • 59 Answers
I take it the machine has adjustable torque setting. perhaps that needs tightening to a higher setting . Usually this is a numbered scale just behind the chuck. Otherwise this part may be faulty.
Posted on Jun 05, 2010
Dewalt 734 thickness planer I want to replace the plate but I cannot remove the screws from the guides Need help.
find out what thread direction the screws are before going brutal---an impact driver may have to be use to remove screws---don't know if they used lock tight on them or not from factory---impact driver is a tool that you insert in to the screw then rap the end of the driver with a mallet/hammer---this action keeps the screw bit buried in the screw and twists at the same time after being hit----this will work only if there's no lock nuts opposite the screw (other end).----GL
Jan 22, 2017 | Dewalt Tools & Hardware - Others
DeWalt 20 V impact. Driver ejects occasionally. Locks in correctly to start then after limited use, bit holder falls out.
These are known for the spring in the nose (#12) to fail.
Using an o-ring pick or small screwdriver remove the hog ring on the end of the bit holder (#17).
Slide the washer, spring, and sleeve off (Be careful not to lose the small lock ball)
The spring that pushes the lock ball forward (#12) is usually the culprit.
Reassemble in reverse order DeWALT DCF886D2 20V Impact Driver Parts
Dec 06, 2016 | Dewalt Drills
I changed brushes in dewalt impact drill ,now it slow is there anything I can do,
The switch is about the only thing that controls the speed of the tool.
If you post the model number I can get you the correct part#
Oct 07, 2016 | Dewalt Drills
My dewalt impact gun dcf885 when I press trigger the motor starts then dies
Mick, this could be a sign of a worn out/faulty motor, mine did this, ripped it apart and it was the motor. Yours may still be under 3 year warranty if you can find your receipt.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeWALT DCF885C2 Type 1 20V Impact Driver Parts
http://www.mmtoolparts.com/store/dewalt-impact-driver-parts
http://www.dewalt.com/en-us/legal/warranty/general-warranty-information
DEWALT ServiceNet
Jun 13, 2016 | Dewalt Drills
How do I change the brushes on a 14" dewalt impact wrench 14.4 volt
I think that model is on a ring internally so there isnt a way to do like the bigger ones, you would have to take the screws out and take in half and you will the the brushes and can replace.
Jan 12, 2015 | Dewalt Tools & Hardware - Others
Dewalt dw297 impact wrench does'nt work at all. the cables does'nt seem broken, so don't know what to look for.
A good place to start with Dewalt tools is the switch. Take the front off the handle and pull the switch out far enough to test the posts on the back. Plug the cord in and check for voltage where the cord attaches to the switch. No voltage, bad cord, replace the cord. If you have voltage, the cord is good. With some help, hold the switch on and check for current on the motor side of the switch. If no voltage, replace the switch. If there is voltage there, you are going to have to check the brushes, armature and/or field for continuity or shorts.
Jun 27, 2012 | Dewalt DW297 3/4-Inch Impact Wrench
Hi from dublin,my third dewalt dw054 impact 14.4v cordless drill,they all lose power,as if the switch does not work,but i think the motor is gone.. They all went the same way after two years..great drill...
Hi there, the first thing you need to do is check the carbon brushes, there will be two of these one at each side of the motor, if these are ok then test if power is getting to the motor, to do this you will need to split the casing on the tool in half. You may need a torx driver to undo the screws on the casing. Once you have removed the screws, very carefully split the casing making sure you leave the gearbox assy, motor and switch in the other half. Insert battery onto the unit and get someone to hold the motor in place just incase the machine starts. get a voltmeter, follow the wires from the switch to the motor and where the wires attach to the motor put the probes of the voltmeter and pull the switch to engage it. You should be gettting a good voltage now, If you are then the switch is ok. hope this is of some help
Dec 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
02-03-09 Tues. 9:30am CST Hi Tech Help I have a DeWalt 1/4" Cordless Impact Driver DW056. It seems to slip when the trigger is engaged when loosening fasteners. I think the driver started impacting...
its supposed to impact immediately that is what gives the tool its power. once you get used to it you will use it for everything its lighter and more powerfull than the drill. just dont use spade bits in it or it will shatter them. try to buy tips that are impact ready
Feb 03, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
453 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
