Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Rinnai 551FT. Can you tell me wether the tray in the bottom of the heater is supposed to have water in it. John
  • wilkie277 Jun 06, 2010
    Yes, thank you. Cheers John.
  • 10,515 Answers
It is a very high efficiency appliance, during operation a small amount pof water is produced in the flue tubes, this drains into the enamel tray. It is quite normal for a small quantity of water to remain in the bottom of the tray.If you are using the humidifier, it will need filling about once a day durying the heating season.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya' and have a nice day!!
Posted on Jun 06, 2010
Minerals in bottom of rinnai heater
If you can take the tray ? put some clr on it this would clean it , or suck it up with vac and try to brush it out .
Jan 09, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 551FT Hi I have just got this model
On the data plate on the heater it will say NG for nat gas or LP for bottle gas
Jun 05, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai Continuum Model 2532 natural gas tankless water heater in my home. It takes about 45 - 60 seconds for the water to get hot at the faucet which is closes to the heater. This thing is...
clean filter on the cold side coming in and clean or replace the aerator at the sink, rinnai works on water flow, common problem if your water hardness to high or if you have iron in your water
Oct 04, 2010 | Rinnai Webstone The isolator EXP tankless...
I Have got a rinnai energysaver 551ft model with no instruction manual am I ment to put water in that front tray? Cheers Kym
Kym,
Yes, if you want to use the humidifier function. No, if you don't. It's just an option.
Below is a link to a full manual for your heater. Check out page 57 for full explaination on this function .
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/230.pdf
Aug 20, 2010 | Rinnai Heating & Cooling
I need to purchase a control panel for a Rinnai gas heater (energysaver 551FT) and Rinnai say they are unavailable
It is true, there are none available. Are you sure that it needs one? what are your symptoms? I may be able to help.
Mar 24, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have the rinnai energy saver 1004f.. Do I have to put water in it for it to work?
Absolutely not. It does help with the humidity but you will find it empty each day because air blows over the water tray when on.
Oct 21, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Need to move the unit by dismantling
Remove the two screws on the side trim. Remove the two top screws from the filter panel. Reach behind the heater and pull the sock down on the vent pipe. unclip the two clamps holding the vent pipe together. Remove the plastic elbow off of the vent termination. Slide the heater to the left to slide the vent pipe off of the vent termination. Remove the gas line after shutting the gas off.
Dec 28, 2008 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Filter light & water mark
The tray is if you want to add humidity. You will constantly be filling it. The filter light could indicate a dirty blower or debris slowing down air flow over the heater.
Nov 20, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Propane tankless Water Heaters R85e-1
Piping of these heaters in tandem is critical. Specified by Rinnai in their design manual, the cold water should be piped to both water heaters with a back-flow presenter installed before the first heater. The hot out piping should be "Tee-d" together and going to your hot water needs.
If piped as per the manual, try turning the water off to only one of the units. Turn on a hot water tap and see if the unit stays on without interruption. Then try the same on the second unit. You may find that one unit has a bad flow control, which is shutting off the flow of water.
You can get more technical help y contacting Rinnai direct at 1-800-621-9419 ext. 207.
Feb 06, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai 551FT (I couldnt see it on list!)
Try vacuum cleaning the filter as the heater shuts down to protect itself from over-temperature. NB-turn off the heater before doing it. And yes, you add water to the tray (...carefully) - this increases the apparent heat. Peter
Jul 15, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
97 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
