Question about Kenmore 13593 Stainless Steel Built-in Dishwasher
No power to dishwasher. water still in dishwasher. Breaker ok
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherno power to dishwasher. water still in dishwasher. - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jun 07, 2010
Dishwasher has not power, check breaker and it is ok. Tub still has water in the bottom. Dishwasher was running and just shut off.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Tip
I get error IE on my LG dishwasher.
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
on Jan 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
VERY LOW WATER PRESSURE TO THE LOWER AND UPPER SPRAY ARMS. FILLS AND EMPTIES NORMALLY
Hello there:
i will post this solution in 2 separate post due to the length of it ok
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
ools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home's electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
Oct 16, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Won't drain and unit will not shut off
water will not go into my dishwasher any solutions
Nov 16, 2009 | Asko D1776 Stainless Steel Built-in...
Dishwasher is not working now
Ok you need to put white vinegar in the dishwasher to kill the foam. You also need to disconnect the unit take it outside and tip it right back so the water can flow out. if it still wont go then you've burnt something out eg the flood switch or RFI module where the power cord goes inside the machine cheers
Mar 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Ran dishwasher, we to work, came home, no power, water in bottom. Breaker is not tripped, power to rest of kitchen
Although breaker has not tripped it is still worth changing the fuse in the dishwasher plug.
Nothing to lose for a few pennies.
Feb 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
IE problem
Possible cause:
Remedy:
Dec 23, 2008 | LG LDF8812 Stainless Steel Built-in...
Whirlpoool dishwasher not turning on model du1050
Make sure you have power to the dishwasher, check circuit breaker. If circuit breaker is ok, then remove toe panel at bottom front of machine, on the right hand side is where the power cable goes into a little metal box. Turn off circuit breaker to kill power to the dishwasher, remove electrical box cover and check to make sure that the wire nuts are tight. Reapply power and test. If still no go then remove tech service sheet from toe panel insulation, get yourself a multi-meter and start test individual components until you find the one that is bad. Hope this helps.
Dec 11, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
LG Dishwasher ie error code problem
Possible cause:
Remedy:
Oct 31, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore 13593 Stainless Steel Built-in Dishwasher Logo
155 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
