TCL ERROR MESSAGE Eo and E5
My split system doesn't heat
5 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: we have just installed our
E5 Outdoor activation of compressor over heatprotection or motor lock
or E5Communication error between outdoor and indoor.
Please check input of out door unit and contacor coil energized. if no power input correct it. If no power in contator coil, mat be the problem PcB thermostat command. Check your setting is 23 dgree and less than that and also mode in "Heat".
Posted on Dec 16, 2010
  • 9 Answers
SOURCE: TCL split sytem aircon has an error faults ER
Try tcl website
Posted on Mar 13, 2009
Sparky2012
  • 102 Answers
SOURCE: I have a TCL 2.5hp split system air conditioner
I will star checking freon pressure but you going to call an HVAC company to do that. Please turn it off or you will damage the compressor, if is not already.
Posted on Dec 06, 2009
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
What is the split pump
A split system has the parts split up between indoors and outdoors. A heat pump heats and cools your living space with the same unit. A split heat pump has the system split between indoors and outdoors and heats or cools your living space. a SPLIT PUMP sounds like something that has broken.
Feb 01, 2015 | Heating & Cooling
My aircon is not blowing
Most liekly needs to have freeon added to the system, if that doesn't help its propely a problem with the electric motor on the blower.
Nov 07, 2012 | Gree 9000 Btu 23 Seer Ductless Mini Split...
A/c will work sometimes, when it doesn't work my cruise light comes on and the security light is on
may need a body control module wich needs to also be programed to car by the dealer
Sep 26, 2012 | 2003 Buick Century
Is a split a/c alc and a heating or heat pump?
a split system can be gas or can be a heatpump. a split system is when the condenser coil compressor and outdoor fan is outside. the other half is in the house close to your air filter .that well be your air handler. eletric heater. or gas burner .and indoor fan motor would be. i hope that helps you.
Apr 15, 2010 | Cfm Daikin R410a Split System Air...
Heating problem with one split in a double split system
Either the board or capacitor have failed. If the motor is HOT the motor could also be the problem. in oder to tell if it is the board you will have to check to see if there is power coming fromthe board at the place where wires hook up. If power is there then it is either the motor or cap.
Feb 02, 2009 | Heating & Cooling
Heating & Cooling Logo
573 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
