Question about Sony Televison & Video
Sony KV27TS20 - Wax dumped in & now not doing much.
Hello everyone.
I have a Sony KV27TS20 (P-3A chassis) that someone spilled candles into (not sure if water was also dumped in at all). The wax was on the AC and high voltage side (mostly towards the back of the unit).
For a while it was blowing it's fuses but after some major cleaning it is thankfully not doing that any more. Though now it is only lighting up the Sleep LED for about a second or two with a very quick flash of the Timer LED when the power button is pressed. I also don't hear any clicks for the relay.
I don't have the service manual yet but would like input to see if its worth trying to recover and what might be the first things to look at in there. There is no scorching on the board at all and all parts look to be intact.
thanks!!!
techman
  • 3130 Answers
SOURCE: RCA Model F36450 Chassis ATC113CA1 won't power up
No sir it probably isent a power supply problem as in these sets it wouldnt act like that. First thingm to check since you say your a service tech, is in the horizontal output check and see if the horiz. output transistors shorted. If its not then check a small coil off the base of the horizontal output transistor. its really the base drive coil so take it out and scrap off the ends BOTH ENDS and reinsert and also resolder the horizontal driver transformer. This may or may not fix your problem But if it dosent order if you think ther sets wrth it the flyback transformer as this is a big problem in these sets if the for mentioned things did do the trick. follow the kit instructions that come with the flyback transformer!! Dont take any short cuts. Make sure you do take out the horizontal output transitor or at least unsolder all the leads when tesating it for a short. Good luck
Posted on May 21, 2006
  • 1694 Answers
SOURCE: power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Posted on Sep 26, 2007
pishta68
  • 593 Answers
SOURCE: My Sony KV-34HS510 Tv will not turn on
Sounds like a power supply problem. The TV is failing its POST (power on self test) and tripping a relay to protect itself. Time for a service call :-(
Posted on Feb 13, 2008
  • 4234 Answers
SOURCE: TV won't turn on, delay/timer light flashing
Please update this with the blink count. That will indicate the circuit in which a problem was found. Once I have that information I should be able to give you the probable cause and remedy.
Dan
Posted on Dec 02, 2008
  • 108 Answers
SOURCE: sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
Posted on Jan 08, 2009
Carpet has candle wax stain. Tried to iron it out with paper and now area where stained is hard.
You can't heat wax it just melts and gose deeper in to the pyle and backing
Try dry scrapeing with a regular dinner knife nothing to sharp and vac and scrape vac .
You won't get all of it out of the backing but the rug should look the same as before the spill
Apr 21, 2015 | Irons
Tip
Cleaning residual candle wax off glass
Believe it or not you can get dried candle wax off of glass with a MISTER CLEAN MAGIC ERASER!! You can use generic erasers , such as Home Depot or your local grocery store. It works !
on May 23, 2015 | Crafts & Hobbies
Tip
Cocktail Candles
1--Blocks of wax--2 Crayon--3-Cocktail glass or Mug--4-Straw or Cocktail umbrella--5-Wick or mop string- --Cut uncolored wax into ice cubes.Put to side-Melt wax and crayon (your choice of color)-Drape wick from pencil into glass-Drop in straw-Fill glass with colored wax- Mash wax ice cubes in to drink before colored wax gets hardLooks very realSet on bar or table
on Apr 13, 2014 | Crafts & Hobbies
HOW DO I GET RID OF RED CANDLE WAX FROM COTTON PLACE MAT THAT HAS BEEN WASHED AND PLACED IN FREEZER. STILL THERE
Candle wax usually melts around 130F, water boils at 212F. Heat the water to 150 or so and the wax will melt, since its lighter than water it floats to the surface, and away from your garment. Let cool, remove wax. Try to make sure the garment stay at the bottom, small weight etc. If the water temp of you hot water is set at 140 you may get away with just letting it sit in that for a while.
Feb 19, 2015 | Crafts & Hobbies
Spilled candle wax on pad covering speakers
Have an auto detailer dry clean it for you. Not the car wash, a real detailer, like the hot rod guys use for their show cars. Super cheap and easy compared to a new door panel or speaker grille.
Dec 09, 2014 | Cars & Trucks
Gow do i remove spilled candle wax from pad that covers speakers
Dry cleaning solvent and a heat gun or hot pad and lots of patience.
Or a detailer can do it quick and easy.
Candle wax from clothing
To remove candle wax from clothes you will need a clothes iron and paper towels. Make sure the iron is on low and the steam setting is off. Take several paper towels and place over the wax stains. Gently move the iron from side to side over the paper towels. Replace the towels as the wax is being lifted and absorbed and be Patient
Rate if Helps
Aug 11, 2012 | Dani 100% Soy Wax Candle Red Clover
How do you remove candle wax from clothing
you will need a clothes iron and paper towels to remove the candle wax. Make sure the iron is on low and the steam setting is off. Take several paper towels and place over the wax stains. Gently move the iron from side to side over the paper towels. Replace the towels as the wax is being lifted and absorbed, and Be Patient!
Rate if helps
Aug 11, 2012 | Cell Phones
Candle wax has been spilled on our sceen
This is a tricky problem as I cannot recommend any type of cleaner to remove the wax. I have in the past used ice cubes to freeze the wax and remove it carefully with a toothpick or something that will not damage the screen. Just try to keep the water under control with a towel.
I hope that this helps.
Aug 11, 2009 | Hitachi 57F500 57" Rear Projection...
Tv sceen
use medical alchool and cotton any thing soft that wont scratc the screen!
plz do rate this post
Dec 05, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Televison & Video Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
