Question about Hyundai Electronics Hyundai Elantra 2004 Stereo/radio Wire/wiring Harness
Abs light is on - Hyundai Electronics Hyundai Elantra 2004 Stereo/radio Wire/wiring Harness
    Top Expert:
  • Hyundai Elec... Master
  • 76,164 Answers
When the ABS light is on it is alerting u to the fact that a fault has occurred in the ABS (antilock brake system) system and the control module has diabled the ABS system, so right now u just have non ABS brakes, there about 20 diff faults that can turn the light on, the way u find out which one is the problem u have a ABS fault code test run by a brake shop or the dealer.
Posted on Jun 04, 2010
Why does my ABS light stays on and sometimes i get a vibration in the brake petal causing my 2002 Cadillac escalade not wanting to stop?
Sounds like a fault with the Antilock Braking System. The vibration in the pedal is the ABS working. With your foot on the brake pedal, it releases and re-applies the brakes to stop a skid from the wheels locking up. You need professional service for brakes.
Seems to be a known issue on all Cadillac and requires the ABS module to be replaced.
ABS Light Due to ABS Control Module Failure : Cadillac ...
repairpal.com > Problems > Cadillac > DeVille Cadillac DeVille ABS Light Due to ABS Control Module Failure. This is a verified problem based on 126 reports. Learn more about this problem, when it occurs ...
repairpal.com > Problems > Cadillac > Seville STS Traction control and ABS lights stay on dash. This is due to ecbtm Module gone bad. replace Module and this should fix the problem. You can go by the VIN and ...
repairpal.com > Problems > Cadillac > DeVille DTS ABS Light Due to Control Module Failure on Cadillac DeVille DTS. The anti-lock ... ABS and Traction control light stays on. ... abs light to abs control stay on.
repairpal.com > Problems > Cadillac > Seville SLS ABS Light Due to Control Module Failure on Cadillac Seville SLS. The anti-lock brake ... SLS135,000Jumsee. Abs and traction lights stay on when started.
Jan 12, 2016 | Cadillac Cars & Trucks
Replaced wheel bearing and speed sensor on RF, 2000 f350 diesel dually. Drove 1 month about 1000 miles, now I get c1145 and c1230 with abs light. Any ideas?
ABS code C1145 - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > 1997 - 2003 F150
Aug 20, 2009 - ABS code C1145 1997 - 2003 F150. ... C1220 Yellow ABS WarningIndicator Failure (2) C1222 Wheel Speed ... C1230 Rear ABS Sensor (Electrical/Static) (2) ... ABS light on (Anti Lock Brakes) and I hear pump when in turn ...
Oct 9, 2010
ABS code C1206-2003 F150 SuperCrew
Aug 13, 2007
ABS light C1230
Oct 22, 2006
ABS light on DTC's C1229,C1230
Nov 18, 2002
More results from www.ford-trucks.com
Nov 17, 2015 | Cars & Trucks
Turn off abs light
Turning off the abs light is not easy to do even if you dissconned the battery the most comeon proble on a abs light to come on proble be n abs sensor each wheel has on you need to put it on a scanner autozone does it for free good luck hope this was helpful good luck
Oct 02, 2015 | Honda Silverwing 600 ABS Motorcycles
Abs and tcs light on 2000 chevy montecarlo
The abs light comes on when a fault is detected with abs system. Your best bet is to have the abs system scanned for trouble codes. Typically loose wheel bearings, or broken abs sensor harness wires are the two most common causes for the abs light to come on.
Apr 01, 2013 | 2000 Chevrolet Monte Carlo
ABS, TRC OFF, VSC and Hand Brake lights on
Clean all the sensors for you abs and wile you there see if the wheel bearings are good and drive shaft, some times they mess with the sensors.
Feb 28, 2013 | Cars & Trucks
91 Buick park avenue abs light. This happened after my friend was driving down the freeway and his tire blew. Now it just blew the rubber off and he was able to drive t off the freeway on the belts. And...
ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti lock brake system light comes up when there is issue with car brake systems. It can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly. Your vehicles brake system needs inspection.
To troubleshoot these issues, I suggest you to refer the help links provided below. There are direct links with accurate solution, for these specific issues.
Click the link below and follow the procedure: ------
All types of ABS LIGHT / brake problems and repairs
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
VCS and ABS lights go on and off intermittently on Lexus?
http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction Control Lights stays ON dash of car?
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Battery Light and ABS Light on Dash
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
How Anti-Lock Brakes Work?
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Anti-lock brake light stays on all the time?
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
2008 Toyota Highlander: ABS warning light Blinking and OBD Error codes Coming?
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
2003 Lexus ES: VSC, TRAC OFF, ABS lights ON?
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
2008 Toyota Highlander Hybrid: Warning Lights Abs, Vsc & Brake Are On?
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
ABS & Brake warning lights remains steady on dash?
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse connected?
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
Where is ABS/TCS module located on 2005 Cadillac Deville
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
ABS motor keeps running?
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON?
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century?
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade?
http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
Toyota Camry: Premature ABS Actuation?
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
Esp and abs light on in 2009 ford transit how do i eliminate them
Anti lock brake system light comes up when there is issue with car brake systems.It can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly.Your vehicles brake system needs inspection.
To troubleshoot these issue,i suggest you to refer the help links provided below.There are direct links with accurate solution,for these specif issue.
Click the link below and follow the procedure:------
VCS and ABS lights go on and off intermittently on Lexus? http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction Control Lights stays ON dash of car? http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
------------- ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
Battery Light and ABS Light on Dash http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while Driving? http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
----------- How Anti-Lock Brakes Work?
Brake System Troubleshooting? http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
ABS & Brake warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse connected? http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
ABS motor keeps running? http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON? http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century? http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade? http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
-------------- Toyota Camry: Premature ABS Actuation? http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
Thanks.
Nov 24, 2012 | Ford Transit Connect Cars & Trucks
Meaning of ABS light
On vehicles equipped with antilock brakes (ABS), a second warning light is provided to warn if a problem occurs within the ABS system. The ABS lamp comes on when the ignition is turned on for a bulb check, then goes out after the engine starts. If the ABS warning light remains on or comes on while driving, it indicates a fault has occurred in the ABS system.
What happens next depends on the nature of the fault. On most applications, the ABS system disables itself if the ABS warning light comes on and remains on.
Oct 24, 2012 | 1999 Ford Ranger SuperCab
Abs light stays on and a yellow triangle warnng light
On occasion an ABS light will come on when a brake light is out. So check your brake lights first. Your ABS light is on because there is a malfunction in the ABS system. Is your brake warning light and your ABS warning light both on? This would be an indicator of a major malfunction in the ABS system. Stop driving the vehicle and fix this immemorially. If only your ABS light warning light is on this will not effect normal braking but the ABS system is disabled while the ABS warning light is on. You still need to have it repaired but you still have brakes for the moment. Now the code for this fault will be stored inside the ABS memory module. So you pinpoint this with scanner. Hope this helps
Mar 22, 2011 | Volkswagen New Passat Cars & Trucks
ABS LIGHT COMES ON AND DISENGAGES THE ABS BUT
When the ABS light is on the ABS system is deactivated. Meaning, when the abs is light is on and you brake, the tires will lock up with heavy braking.
Escapes have a common issue of the ABS excitor rings cracking causing ABS problems. Sometimes it activates on almost every brake application. It may set a code in the ABS computer for an intermitten wheel speed sensor or no wheel speed signal. Check all the "rings" on the outside of all four axleshafts. If none of the rings are cracked it is likely a bad ABS wheel speed sensor.
Feb 20, 2010 | 2002 Ford Escape
Hyundai Electronics Hyundai Elantra 2004 Stereo/radio Wire/wiring Harness Logo
412 people viewed this question
Top Hyundai Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a Hyundai Electronics Car Audio and Video Expert? Answer questions, earn points and help others
