When changing from the westell bellsouth box over to the linksy router, i am unablt to get internet, it is loaded in the computer from the disc, but the internet lite will not come on,,, when the computer is tryin to read the detection part of the router it is saying not supported and i have xp... and all 4 lights go on and the internet light goes but, still no connection
No, I didn't get it fixed, but after purchasing computer and router, I dont have anymore money to purchase a plan. Thank you anyway
Posted on Apr 10, 2008
I am trying to connect to the internet using the linksys WRT54G and a motorola modem from AT&T. The computer recognized and connected to the Linksys (set up was very easy), but the internet will not...
The steps will very some depending on the model of the modem and router but these steps should help.
How do I proprly set up a Linksys router for FastAccess DSL? Important Note: Due to some operational issues it is VERY important that you have the latest firmware on your Linksys router. Please go to the Linksys Download Website and ensure you have the newest firmware.
Configuration of a Linksys router depends on the type of broadband service and other equipment connected. This is a generalized Linksys Router FAQ and some firmware, capabilities, and actual screen shots may vary. This initial setup is all that is needed to configure and connect your Linksys based network for FastAccess. Any additional setup for features like WEP, DHCP IP ranges, port triggering, etc is out of the scope of this FAQ. Other FAQs may be more appropriate and provide more specific information:
•If you are using a BellSouth supplied Westell 2100/2200/6100 modem please reference the FAQ here.
•If you are using a BellSouth supplied Motorola/Netopia 2210 modem please reference the FAQ here.
•If you here IFITL (PCData) service please reference the FAQ here.
•Both the modem and router must be reset to default.
•The BellSouth Installation CD and Connection Manager are not required to use this configuration.
•Since BellSouth assigns static IPs via your username the configurations shown are applicable to both dynamic and single static IP customers.
• You will be using the PPPoE client built into the Linksys router for connectivity/authentication. Please delete any other unused PPP clients like Enternet300, RASPPP, or the native XP client.
Section 1 - Linksys Router Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Power down the router and any PCs. Connect one of the router's LAN ports to the computer NIC and power up the router and then the computer. Reset the router to default by pressing the reset button for roughly 25 seconds (exact placement of the button differs per model).
bred.gifStep 2
Important note: The following screen shots are based on a Linksys BEFSR41v.2 router and your screen shots may be different, however the process and configurations are the same. Open a browser session and enter 192.168.1.1 in the address field to access the Linksys Interface. At the Username and Password prompt enter admin (without quotes) in the Password Field.
bred.gifStep 3
On the Linksys Setup page select PPPoE from the WAN Connection Type pull down. Enter your BellSouth Username followed by "@bellsouth.net". Enter your BellSouth Password. Select Keep Alive and enter 180 seconds Redial Period field. Do not enter anything in the Host Name or Domain Name fields. If your model has the ability to adjust MTU size (not shown below) select Enable or Manual and enter 1492 in the Size field. Click on Apply to save the changes. You may get a "Settings are successful" message, click on Continue (if required).
Section 2 - Physical Connections and Power Up
bred.gifStep 4
Power everything down and physically connect the modem, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 5
Power up the network equipment in this order:
Westell or Motorola Modem (wait for DSL synch)
•Linksys Router
•Computer(s)
•Open a browser session and enter "192.168.1.1" in the address field to access the Linksys Interface. Click on the Status tab from the menu then click on the Connect button to connect to the Internet.
•Go surfing!
bred.gifImportant Additional Information
•The Westell 6100 and Motorola 2210 modems have an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the Linksys to establish the PPPoE session the light will stay off. This is normal.
Do not change the Linksys Operating Mode from Gateway Mode (default setting) to Router Mode, or it will not function correctly.
•The Linksys "Auto" MTU capability does not function correctly on some models/firmware. You must manually enable the MTU and adjust the size to 1492 (or less). If you are experiencing slow/erratic speeds, constant disconnects, or receive a "Can not obtain IP address from the server" or "PPPoE negotiation fail" errors click here.
•You should check your tweak settings to optimize your new network. Reminder: If you change your MTU, make sure that it is set identically on all equipment (PCs and routers) in the network.
I hope this was helpful,
Shawn
Jan 29, 2011 | Linksys Wireless-G WRT54G Router
The internet connection is fine (DSL AT&T).
1. You may have a an IP address conflict.
2. check the device connected to the router
all computer need to be connected at the same time.
3. Bring all the computers up one at a time and this should resolve the address conflict.
May 16, 2010 | Linksys WRT54GX4 WIRELESS 802.11G...
I have a linksy cisco and westell model 6100 and the wifi is not working-- i can only access the internet when i hook up my computer to my westell model--- whats wrong with my wifi?
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 13, 2010 | Linksys Wireless-G WRT54G Router
Can't connect my wrt56gs to my westell 6100 modem, could you please help?
You are using westell modem that means your internet service provider must be DSL.You will need to make sure that your computer is able to go online when connected to the modem. that will decide the type of ISP connection.
Click Here for more info on how to set up the router.
Oct 18, 2009 | Linksys Wireless-G WRT54G Router
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Oct 07, 2009 | Westell Wirespeed VersaLink...
The Linksys WRT54G ver.6 worked until yesterday when I lost access to the internet. The "power" light is blinking continuously, so I went through the troubleshooting exercise of power off, power on - no...
Blinking power light usually indicates device being faulty. Was there a power surge? Try resetting the router by pushing the small reset button at the back with a pin for 10 seconds, then power it off and on. See what happens
Jul 05, 2009 | Linksys Wireless-G WRT54G Router
Set to work with centurytel instead of bell south
Howdy - You may have a two fold problem here. First of all the Westell wireless modem/router 327w has the access IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. That problem solved...
Now, from what I understand, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
That being said, you still might attempt to use this 327W with centurytel but I do not know if it will work. I use the Bellsouth 327W and it is GREAT. Good luck.
May 29, 2009 | Westell Wirespeed VersaLink...
Slow or no connectivity with linksys modem
- Changing the LAN IP Address of your Linksys will do to fix the issue.
Mar 16, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
bred.gifStep 7
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Mar 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Changing from DSL to Road Runner Turbo
I'm sorry to say but you cannot bypass the modem capability of the DSL Westell Modem/router because that is really made to function as a DSL modem and a router at the same time, so the best way to make everything work here since you change from DSL to Cable internet just need to get a wireless router like a Linksys WRT54G that can make everything work again like before.....
Nov 05, 2008 | Westell Wirespeed VersaLink...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
