Question about C3RS730 LCD
Wire spliced and now alarm wont let car start.
Wire from alarm was spliced to install power windows. Now car wont start. alarm works fine but the car wont start.
  • Wilson Martinez Jun 05, 2010
    What car are you working with Year/Model /Made and the alarm
    remote start made/ model you installing, then what is the wire you spliced.
    New Friend:
  • 103 Answers
You will need to diode isolate the wiring that was spliced. It is backfeeding into the starter diasable circuit, and causing the vehicle not to start.
Posted on Aug 13, 2010
How do I remove alarm brain box from wiring on a
"I bypassed the immobilizer circuit only on my alarm module (which is really tedious). Bypassing the whole
module is possible (and little easier), but you will lose the use of the remotes and the ability to arm the alarm.
The alarm module in my '97 900 SETC is located under the carpet, below the driver's power seat switches (a
pain to get at).
If you want to bypass the module completely:
1. Disconnect the battery (make sure you know the radio code-if needed)
2. Unplug the connector from alarm module and remove module from car
3. Install a wire jumper between pin 8 and pin 20 in the connector
4. Install a wire jumper between pin 9 and pin 21 in the connector
5. Install a wire jumper between pin 10 and pin 22 in the connector
6. Wrap securely with electrical tape
If you want to bypass the immobilizer circuit only:
2. Unplug the connector from the alarm module
3. Cut the following wires from the back of the connector and splice together as follows (Don't cut the wires too
close to the connector, because someday down the road you may want install a new module, so you'll have to
reverse this process):
4. Cut the wires to pin 8 and pin 20 and splice together w/ wire nut
5. Cut the wires to pin 9 and pin 21 and splice together w/ wire nut
6. Cut the wires to pin 10 and pin 22 and splice together w/ wire nut
7. Secure all with electrical tape
8. Reconnect the connector to the module
Not knowing the details of your problem, please be aware that this may, or may not, solve it. Good luck and let
me know how you make out."
Oct 02, 2014 | 1997 Saab 900
Left power window wont work
there is no power going to that window so splice the power wire from the front passenger window into the power wire of the window that isn't working
Jan 26, 2014 | 2005 Toyota Corolla
Autopage alarm rf 220
IT IS POSSIBLE THAT THE ALARM HAS FAILED. WHAT YEAR IT THE TRUCK. THE WIRING WILL BE AT THE KNEE BOLSTER. YOU WILL SEE A YELLOW HEAVIER GAGE WIRE THAT IS THE IGNITION WIRE.THE WIRE WILL BE CUT AND SPLICED INTO THE ALARM WIRING . JUST CUT AND SPLICE THE WIRE TOGETHER AND SEE IF IT STARTS. DEPENDING ON THE DETAILS OF THE TRUCK YEAR AND SUCH. WIRE CAN CHANGE COLOUR, POST TRUCK DETAILS AND I CAN POST WIRING DIAGRAM.
Jan 22, 2014 | Vehicle Parts & Accessories
Intermittent alarm going off, can I disable the alarm sounder.?
Yes.... There are many options but few work. This will definitely work. Just had to do it today. In drivers side door kick panel there is a Purple/Yellow wire. Splice it and run a wire from the splice to a ground. Turn the key and start engine. Works.
Jun 01, 2013 | Cars & Trucks
Fitting SPY 5000m Alarm Suzuki Bandit 1200 NOT WORKING
wiring diagram would be helpful if theres a link, have you taken the ignition power source from before or after the switch. i.e does this need a live continual power or just on power.
Mar 10, 2013 | Motorcycles
I have a 1992 Lexus es300 it has lost all power I put a new battery in and it started up for me but now I can get it to start or do anything I don't have a key alarm to deactivate the alarm and the ke
Well it looks like car had a after market alarm installed. If so, The siren has been removed. But the alarm brain box remains powered up under dash. You have to find it and remove it. And there is a relay that is a part of the alarm system. It basically interrupts the starter circuit. Just remove it and splice the 10g wire back together the way it came from factory. That's it. Car should start no problem.
As far as windows that probably is separate.
The hood is also seperate issue I believe.
Dec 29, 2012 | Cars & Trucks
Factory installed alarm keeps tripping itself and causing my van to not start.
Its better you reomove the installed alarm you dont have to remove and restore everything just 2 things the ignition that has be interrupted and the factory alarm in the hood just cut the alrm horn wire. For the ignition you will have to go under the console and remove the panel to access where they have interrupted the original wire. Identify the the ignition wires there you will see where they have splice a wire to a relay match thhe colors that they interrupted and restore that wire (its a 4 wire relay) use a but connection and ensure it does not fall apart start the car if the alarm horn goes off just cut it(NOT the car horn)cansmo_110.gif
Aug 28, 2011 | 1997 Chrysler Town & Country
MY CAR WONT START BECAUSE IN AFTER MARKET ALARM. hOW DO i BYPASS THE ALARM TO START THE CAR
I've ran into this problem myself, if you're not confident with doing some wiring you probably should not be doing this. This will probably take 1 to 3 hours to do this. If you can get a wiring diagram that showed how the alarm was originally installed. If not find the alarm probably underneath the dashboard, the alarm wires will problem be smaller than a wiring that is in your car. When removing the alarm think of it as this way, someone cut into the middle of your wiring harness and put a alarm in. Would you need to do is remove the alarm and splice the cut wires back together. Instead of removing the alarm all at once try disconnecting one wire in a time and finding its mate. The wires or color coded. For example, black with an orange tracer. This would mean it's a black wire with an orange line on it. If you're not sure look at a wiring diagram splicing the wrong wires together could cause your car not to function properly or damage it. Before you start this make sure you disconnect the battery also. Good luck.
Jul 18, 2010 | 1998 Ford Mustang
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
May 08, 2009 | 2003 GMC Sierra
04 Jeep Power Windows
THIS REALLY WORKS****** Saved atleast $600 easy
Ok so when you open your driver door there is a black boot that goes from the body of Jeep to the door (inside the Jam when you open door-its visable) Take this loose...inside there is a wire bundle...there was a black and orange wire in there that were both broken....All we did was strip these and reconnect them w/ connector....Voila..windows all roll up and down..interior lights come on and the locks work and the power mirrors....I AM SO HAPPY THAT THIS WORKED SAVED ME SO MUCH $$$$
Jan 25, 2009 | 2004 Jeep Grand Cherokee
C3RS730 LCD Logo
368 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
