Question about Kenmore 24422 Top Load Washer
My switch is out of adjustment or needs replacing on my mod #24422300----how do I get the lid off of the machine to get to the switch
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24422300&pathTaken=partSearch
It has diagrams of all major components and their relationships.
Next, see the following for how to release the console and remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=affe8ede600431516767e8e3f033eb7a
Basically, if you snap off the end caps, you should see a phillips head screw on each end of the console.
Remove the screw, pull the console to the front and up.
Posted on Jun 05, 2010
Could it be my lid switch.i just replaced the timer and that was not the problem. the machine seems to go through all of its functions but does not go into spin cycle mod. whdsr315daww
yes it could be the lid switch,,, they put the lid switch on there as a safety to shut doen when lid is opened and it will do the same if bad will not allow the unit to come on .... good luck to you hope this helps you out...
Jan 08, 2011 | GE WBSR3140DW Top Load Washer
WILL WASH BUT IT WILL NOT SPIN AND THE WATER IS SETTING IN THE MACHINE MOD - LXR5432KQ0 SER #CM3226867 TYPE 107
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. The part number for a replacement for your washer is 3949247.
NOTE: You DO NOT need to drain the washer to replace the lid switch. Once a defective switch is replaced, the washer will drain.
If you have questions, or need additional assistance, please post back and let me know. I hope this information is helpful.
Mar 18, 2010 | Whirlpool LXR5432KQ Top Load Washer
Kenmore mod 23832100 Lid Switch broken HOw do I
Good day,
There are 3 different style lid switches used on Whirlpool/Kenmore washers. You have to break down the unit to determine which one you use. Any appliance parts house will carry what you need.
Here is an excellent tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 01, 2010 | Kenmore 23822 Top Load Washer
Machine stops when it gets to spin mode
This sounds like the lid switch is bad, or needs adjusted. In the center of the lid, on the rear of the lid, there is a little "nubby" that pushes on the switch. Make sure it clicks when the lid is closed. If not, try pushing back on the lid a little to get it to click. If it does, the switch needs adjusted. If not, it may need replaced. If this helps, please rate my answer. Thank you. If it doesn't help, we will take it further and try and get you fixed up.
Jan 06, 2010 | Maytag Washing Machines
Whirlpool Ultimate Care top load
Likely, the lid switch needs position adjustment or replacement. Open the top cover to access the switch. Connect the two switch wires together and tie up so that they can't short out to anything, then run the machine a couple of times to see if this fixes the primary problem. If so, reconnect the wires, then try the switch adjustment for fix, then replace the switch if adjustment fails.
Sep 07, 2009 | Kenmore 24032\24036 Top Load Washer
Waher dont work
Check the top lid interlock switch. If the switch is bad or out of adjustment, the washer will not agitate or spin. This is a safety feature so no one can reach inside while the machine is running. To check if the switch is working, open the lid and SLOWLY close it,going as slow as possible when the lid is almost closed. Just before the lid "hits bottom", you should hear a CLICK sound. This is the lid switch actuating. If you do not hear the click, the lid interlock switch needs replacement or adjustment.
Aug 09, 2008 | Washing Machines
Tub will fill the machine will agitate but when time to drain nothing happens
you need sto check your lid switch , open and close your lid a few times and listen carefully, do you hear a clicking noise?? if not the machine doesnt think the lid is down and wont spin for safety reasons, repalce lid switch p#3949247(if that vcorrect mod num lsq9564j
Feb 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 24422 Top Load Washer Logo
146 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
