Question about Kodak EasyShare V550 Digital Camera
Lzoom lens goes out and in, immediately, then camera turns off
Zoom lens goes out and in immediately when I turn on, then turns automatically off. All else works. Pl. advise. Kush
  • 4 Answers
Hey Kush update the v550 firmware. I had the exact same problem and that fixed it.
Posted on Apr 24, 2008
    Problem Solver:
  • 3 Answers
Pull the battery and plug the charger into the camera. It should turn on and take pics now. If it does, you need a new battery!
Yeah, I know, the battery shows fully charged but it's weak and old so it really doesn't have the current to drive the lens.
Try to clean the battery terminals with an abrasve pencil eraser, (old red eraser #2 pencil from grade school) and wiggle the battery in the camera (gently) to clean the terminals inside the camera.
Let the camera charge the battery completly, (not in the dock!) and see if it turns on.
If it does, you will probably find that it discharges VERY quickly.
Buy a new battery! That extra battery that you have had since you bought the camera is probably also shot! They do have a shelf life!
If the camera does not turn on with just the charger, (no battery) then it's probably a lens error, but you should see an error code if it is.
Posted on Apr 20, 2008
WB610 Camera buttons & lens aren't working as they should?
As soon as the camera is switched on, the lens barrel will come out. Everything should be ready to shoot pictures. If it is not responding to the buttons, you could try to remove the battery for a few moments. It will cause the camera, to start from scratch. Call it a cold boot. But then after switching on, it should respond normal, like you used to work with it. If it stays frozen, visit your dealer or contact a Samsung certified repair centre.
Mar 10, 2015 | Samsung WB610 Digital Camera Black
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
Zooming problem
hi sanjeev,
Thats a only reason of turn off. Try one more things if you success then fine otherwise plz visit service center. I think you zooming botton internally short with power connection. Before that scan your memory card may be reson of virus. or remove your memory card format your internal camara mamory and try.
Jan 31, 2010 | Canon Cameras
When the camera is turned on the zoom lens goes in to max mode an
Your zooming button is faulty. You will have to contact service center, if you're not sure how to deal with repairing it yourself. The matter is simple, and it won't cost you much.
Dec 22, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Canon A95 Cannot be switched off
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jul 05, 2009 | Canon PowerShot A95 Digital Camera
My sony cybershot 12.1 megapixel camera turns off and immediately turns off?
Hi, This problem is related to the lens block assembly, when turns the power the zoom motor stuck and set goes in power off mode. To rectify the problem you have to replace the lens block assy. you didn't mention model No. here so that i am not been able to tell you the exact part number of the camera. Thanks for using fixya.
Jun 14, 2009 | Sony Cameras
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
May 22, 2008 | Canon PowerShot A540 Digital Camera
Automatically turns off...
possible lens failure ( or - damaged ) ; up to 50 % of replacement cost is reasonable repair ( if more , trading up is advised ) ;
Jun 28, 2007 | Panasonic Lumix DMC-LZ3 Digital Camera
Kodak EasyShare V550 Digital Camera Logo
78 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
