Question about ASUS Eee PC 701 Notebook
Enter key plus dash comming up everytime i push enter how do i fix problem
  • Bob  Adam
    Bob Adam Jun 05, 2010
    Did you spill something on the keyboard. Or could someone else have spilled something on it. Typically when two keys work at the same time, it means that a liquid spill has occured and you need a new keyboard.
  • shannon_thow Jun 05, 2010
    no not that i recall but i cant change key board as it's attched to my nebook
    Scholar:
  • 113 Answers
You can try to test this by plugging in a USB keyboard into the system and pressing the key in question. If it works as it should it will act normally. If it does than the keyboard would need to be changed. Keyboards are replaceable,
Posted on Jun 05, 2010
Sigma 8000 plus fix 24 error. I know what the error is for but how do you fix it?
Someone pulled out the tubing improperly. First check to see if all the tubing has been removed, and no little pieces have been left behind.
Step 1. Push Options. type code 89 then push enter.
Step 2. (on screen reads Set Bio Options) type code 430 then push enter.
Step 3. (on screen reads Password) type 9250 then push enter.
Step 4. (on screen reads Fix 00 then turns off).
Step 5. Turn on and check for any more errors.
Oct 08, 2011 | Cameras
Everytime I input a negative sign in the PV figure in the tvm solver I get syntax error
Use the (-) key to the right of the decimal point key instead of the - key to the right of the 6 key to enter negative values.
Feb 04, 2011 | Texas Instruments TI-84 Plus Calculator
When I put new batteries in the TI83 plus calculator i get the message RAM CLEARED. You have to push very hard on the buttons to get a number to register but it does give correct answers. Any idea why I...
While trying to fix a problem with my calculator I came across this reset process. It might help you... http://www.ehow.com/how_5121373_reset-ti-plus-calculator.html
Jan 07, 2011 | Texas Instruments TI-83 Plus Calculator
I get ERR: DOMAIN everytime I try to inverse a matrix
  1. First, Press the "MATRX" button
  2. Next, enter a matrix into the calculator. To enter a matrix, press the arrow that points to the right two times when the cursor highlights letter "A." This moves the top cursor to "Edit." Press "Enter" to select the "Edit" option.
  3. Next,, enter the matrix's numbers into the matrix on the calculator. Press "Enter" to move the cursor over one column. Press a button that has a dash symbol within parenthesis [( - )] to move down one row. Repeat the steps until the matrix is completed.
  4. Next, Press "2nd" then "Mode" to go back to the home screen. Press "MATRX" to enter the matrix screen again.
  5. Finally, press "Enter" when the cursor highlights matrix "A" then press "[x^ -1]." Your screen should read "[A]^ -1." Press "Enter" again to display the inverse matrix.
    I got this information from eHow.com
Dec 07, 2010 | Texas Instruments TI-83 Plus Calculator
TI-84 Plus Calculator: my calculator screen is black everytime i turn it ...
Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key for a few seconds until the screen lightens.
Obviously, if you've gone too far, press and release the 2ND key, then press and hold the up-arrow key.
May 17, 2010 | Texas Instruments TI-84 Plus Calculator
Im using the geometricpdf and everytime i plug in numbers and press enter it gives me err:argument. How do i fix this?
Make sure the first argument is a number between 0 and 1, inclusive. Make sure the second argument is an integer or a list of integers.
May 10, 2010 | Texas Instruments TI-83 Plus Calculator
Everytime i wants to format my pendrive it say disk is write protected,how can i solve this problem?
The way to do so is simple
just follow the instructions
we are going to edit the registry in xp for that
Use Registry Editor with caution
1) Click Start->Run.
2)Type regedit and hit enter.
4)Click on the plus sign next to HKEY_LOCAL_MACHINE
5)Click on the plus sign next to SYSTEM
6)Click on the plus sign next to CurrentControlSet
7)Click on the plus sign next to Control
8)Click on the plus sign next to StorageDevicePolicies
9)Write click on WriteProtect and click modify.
10)If the value data is 1 change it 0 and click ok.
11)Repeat steps 7 to 10 for ControlSet001 and ControlSet002 .
12)Close Registry editor and restart the computer.
If you don't find it in the registry, the best way is to create it yourself. Below is the procedure.
Start the Registry Editor
Go to the HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control key
If there is no key called StorageDevicePolicies, create it
You do this by right-clicking the HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control key, and selecting New > Key from the menu.
Select the StorageDevicePolicies key
From the menu select Edit > New > DWORD Value
Name the new value WriteProtect
Right-click the WriteProtect value and choose Modify
In the Value Data: box enter 1
Exit the registry editor, and restart your computer
i think this will solve your problem
Please rate and vote
Feb 20, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a problem with my Zen V Plus
You can use the support page from Creative to resolve this problem.
Go to next link for the Zen V Plus and enter the word "firmware"
in the knowledgebase bar:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=15306&prodName=ZEN+V+Plus&bTopTwenty=1&VARSET=prodfaq:PRODFAQ_15306,VARSET=CategoryID:213
Next select item 5 to go on with going for a step by step solution.
Need more help ? Just post a comment.
Dec 18, 2009 | Creative Labs ZEN V Plus MP3 Player
Keys arent functioning properly
Reset RAM . If keys are not working properly, calculator is of no use to you. You should have it repaired.
Hope it helps.
Sep 12, 2009 | Texas Instruments TI-84 Plus Silver...
ASUS Eee PC 701 Notebook Logo
69 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
