Question about Dirt Devil M086700 Vision Bagless Upright Vacuum
It stopped picking up dirt . I cleaned the filter, and the belt isn't broke on it. What do i do
  • 903 Answers
Does the belt spin when you turn the vacuum on? There is likely hair wrapped around a brush or roller, or dirt clogged up inside the nozzle somewhere.
Posted on Jun 05, 2010
It runs but not pick up dirt in cup
Hello! If the dirt is not entering into the dirt cup this could mean there is a clog in the vacuum or a filter that needs to be cleaned or replaced. Check that the brushes are still spinning. The vacuum has a brush-roll shut-off pedal on the right side of the cleaner if you are standing behind it. Below are simple instructions for checking your vacuum for clogs.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
9. Inspect the belt for damages, if the belt is broken replace the belt with a Genuine Hoover belt part 562633001 Flat Belt Nano Upright
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Mar 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
Would a clogged hepa filter cause the vacuum to stop picking up dirt? There's suction on the hose when I checked it.
Generally the Hepa filter is a bypass filter in which there is another filter on the unit. Check to ensure that the belt is allowing the rollers to turn the brush. Just suction on the line won't pick up deep dirt unless you allow to sit in place.
Oct 05, 2010 | GE 106585 Upright Vacuum
Not picking up dirt
clean ALL the filters or buy new one it would be better to buy all new filters also check for clogs in the vacuum also check the belt if the belt is broken it will not pick up much 1. check all tubes for clogs if still dose not pick up 2.check the belt and replace if broken if it still dose not pick up 3.do the filters that worked on my bissell
Feb 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
My bissel vacume was not picking up the dirt on the carpet. So I found that the hose was clogged. I unclogged it but the vacume still is not picking up the dirt. I also changed the filters.
I found out that if you remove the front filter holder, tip vacuum back and look down inside. Sometimes there is hair caught back in there and you won't get suction. I had to use something long, knife, very long type tweezers, to pull all the hair out. Worked great after that. About half way through vacuuming I will stop and remove the foam rubber filter and clean it. Oh yea, you will have to use a flashlight to look down inside to see all the hair caught behind the foam rubber filter cup.
Dec 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
The belt broke and after putting on new belt I dicscovered the cylinder with the brushes attached wasn't turning. After I finally got the cylinder to turn it makes a very very loud noise and also now it...
Check the cylinder with brushes does not have hair or carpet fibers causing it to bind. With the belt removed the brush should turn freely and fairly easy. The original belt probably broke because of this. You may have to fully dis-assemble the head of the vacuum to clean the entire brush assembly.
Sep 19, 2009 | Dirt Devil Vacuums
My self-propelled windtunnel bagless hoover does not pick up.
Remove the filter screwed in at the top of the dirt cup opening.
Remove the hepa filters on the side of the machine.
Clean all filters and re-install them.
Feb 21, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Swivel Glide
look on the underside where the brush roller is and unplug it first then try to turn the brush roller by hand,if it turns real freely the belt is broke.you might have a clog at your intake hose at the bottom its the clear looking hose that goes from the bottom and comes up the back.if the belt is broke before you put a new one on clean the motor shaft there might be some old belt rubber on it ,otherwise the new belt won't last
Jan 03, 2009 | Dirt Devil Featherlight Bagless Upright...
Bissell turbo revolution
you can wash that sponge filter by hand but you must let it dry compleatly before putting it back in the machine, I found a filter pack for the lift off vacume at walmart, make sure teh bottom filter is clean as well. the lift off vacume has 3 filters there is one filter in the tray under the dirt cup, one in the top cup, and the hepa filter in the back the 2 foam filters must be clean or you can have reduced suction, the lift off vacume I have I found thrown away because they never cleaned it outthe brush was dirty and full of strings the belt was worn, the hose under the vacume was full and stopped up the hose in the back was compleatly stopped up all filters were compleatly clogged, and the hepa filter was missing entirely. Not to insult you or anyone but i've found that a lot of people are jsut to lazy to clean their vacume out it fills up with dirt they throw it away and get a new one, i've gottten many like new vacumes for this reason, this bissell is working like brand new now. and I just replaced the belt and all filters in it saving me approx. 150.00 for a new one
Dec 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dirt Devil M086700 Vision Bagless Upright Vacuum Logo
145 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
