Question about Kicker KX200.2 Car Audio Amplifier
How come it blows 30 amp atc fuse instantly even with the system off
Instant fuse blowing? Follow the circuit board traces from positive to negatve; you probably will come across a large diode that bridges + to -. This protects against reverse polarity hookups, and is designed to short out; protecting the amp by blowing fuses.Pull the diode and replace, or pull it and hook up power correctly; then any other probs can come to light.
Posted on Sep 29, 2012
    Problem Solver:
  • 19 Answers
Check connections are hooked up properly if it blowin the fuse with it off sounds like something is really wrong on inside get it checked out
Posted on Jun 06, 2010
2001 jeep grand cherokee,heat and a/c do not bloww hot or cold air
Bernard,
HVAC failure
the car has 2 classes of HVAC< manual and ATC
the blower must blow on high.??? does it on high?
if not, check fuses, for blower. (if lower speeds only fail say so)
the blower is dead,
then say if dash controls are Manual or ATC<
atc = automatic temp,controls with a dash thermostat et cetra.
the diagnostic path is different.
the ATC has self test too. .with over 30 errors possible.
use comments to respond, not a new post. please.
Dec 06, 2016 | 2001 Jeep Grand Cherokee
Find a Diagram for 1989 Lincoln Towncar 4 Door Fusebox
this is for the base model
FUSE PANEL IDENTIFICATION (1983-90 LINCOLN TOWN CAR) The fuse panel is located in the instrument panel to the left of the steering column. To expose fuse panel, remove lower steering column finish panel.
Fuse & Circuit Breaker Identification
· 1 - 15 Amp Stoplights, Hazard Warning Lights, Speed Control Module, Trailer Tow Relays, Cornering Light Relay (1983-89)
· 2 - 8.25 Amp (Circuit Breaker) Windshield Wiper/Washer
· 3 - Blank
· 4 - 15 Amp Taillights, Side Marker, License Light, Parking & Coach Lights, Cluster Illumination, Trailer Tow Relay
· 5 - 15 Amp Turn Signal & Back-Up Lights, Trailer Tow Relay, Cornering Light Relays, Heated Rear Window Relay, Rear Defrost (1988-90), A/C Clutch & ATC Module (1990), Load Leveling (1990)
· 6 - 20 Amp Heated Rear Window Control, Speed Control Module & Clock Display, Illuminated Entry Module, Power Window & Police Accy Relays, Fuel Filler Door Release (1983-87), A/C Clutch & Cornering Lights (1983-89), Deck Lid Release (1987-90), Tripminder
· 7 - 10 Amp Daytime Running Light Resistor (1990)
· 8 - 15 Amp Dome LP-Clock, Key Warning Chimes & Electric Mirrors, Courtesy & Visor Mirror Lights, Autolight & Illuminated Entry Modules, Tripminder, Electronic Radio Memory, Trunk & Underhood Lights
· 9 - 15/30 Amp Heater Blower (15 Amp), AC/ATC Blower (30 Amp)
· 10 - Blank
· 11 - 20 Amp Radio & Power Antenna, CB Radio
· 12 - 20 Amp Door Cigarette Lighters, Power Seats & Door Locks (30 Amp), Tailgate Power Window (1983-89)
· 13 - 5 Amp Illuminated Outside Thermometer, Instrument Panel Lights
· 14 - 20/25 Amp (Circuit Breaker) Flash-To-Pass, Sun Roof, Power Windows
· 15 - 10 Amp Taillights, Parking, Side Marker/Coach, License Lights
· 16 - 20 Amp Horn & Front Cigarette Lighter
· 17 - 15 Amp Electronic Cluster, Message Center
· 18 - 10 Amp Warning Indicator Lights, Throttle Solenoid Positioner, Low Fuel Module & Autolight System, Dual Timer Buzzer & Electronic Chimes, Electronic Message Center
Feb 11, 2015 | 1989 Lincoln Town Car
Why does the ATC fuse keep blowing
Fuses only blow when the current is above the limit. Tripping a 20 amp fuse is a serous current, probably caused by a shortage. Check if an animal has eaten on your cables, or perhaps a cable lost its isolation and is now connected to the plating. Use a ohm meter and try to follow the cable from the fuse to in the car, till toy see something.
Jun 30, 2014 | American Terminal ATC-20-50 20 Amp ATC...
My atc fuse would keep blowing I put a bigger fuse it didn't blow that but I herd a zap noise from my TCCM now my 4x4 won't work 1999 jimmy
What you have done? You Just damage the TCCM and that's why you will not manage to shift 4x4. Why this happened? Because you had shortage somewhere and you receive blown ATC fuse.You put a bigger fuse in capacity where the was stronger to blown and the fault moved to the tccm system which was not protected and blown.Ask for an expert to check and see whether the fault is easy to get fixed.
Jan 02, 2013 | 1999 GMC Jimmy
What fuse does my maxon mcb-30 cb take
12 volt 2 amp kinds or any 0.5 amps even. You want it to blow fast to save radio from damage. So, any type 0.1 amp to 1 amp or 2 even. It doesn't matter; but a fast blowing one will save radio from damage later on.
Apr 04, 2011 | Maxon MCB-30 40-Channels Base CB Radio
I have a have 2000 chevy tahoe I need to now why my atc fuse keeps blowing out
the fuse is blowing because there is a short circuit somewhere in the system,,, to help you further I will need to know what fuse it is that is blowing AND what is it that you are doing WHEN the fuse blows ??? what is the Amp rating of the fuse that is blowing ? and in the owners manual ( under FUSES ) what Amp rating does it call for ??
write me back with this info and I will do my best to walk you thru the next steps to solve this problem.
thanks,
c...
Feb 03, 2011 | 2000 Chevrolet Tahoe
30 amp fuse blow's
is it the crank fuse if it is could be starter drawing to many amps try new starter
Feb 13, 2010 | 2000 Ford F350 Super Duty Super Cab
Blowing atc fuse
you have a short in the circuit somewhere. look for a wire that has been rubbing on something or has come lose and is grounding out.
Dec 31, 2008 | 1999 Chevrolet Silverado 1500
Blowing 30 amp engine control fuse.
You say it eventually allows you to put new fuse in, do you mean when it sits for a while, a new fuse won't blow, but if it blows and you immediately replace it, it blows again instantly?
Sep 05, 2008 | 1997 Dodge Ram 1500 Club Cab
Kicker KX200.2 Car Audio Amplifier Logo
148 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
