Question about Hasbro Fur Real Friends Smores Pony
Hasbro S'mores tail broken off, makes clicking noises when neck and head try to move. are parts available.
    Problem Solver:
  • 8 Answers
Not sure about the clicking but her is how to repair the tail. Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Jul 23, 2010
How to fix my kota triceratops neck?
New you tube video 2:50 min video called Kota dinosaur
broken/hanging neck repair
Jan 16, 2016 | Hasbro Playskool Kota and Pals Stompers -...
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Dec 08, 2013 | Hasbro Furreal Friends Butterscotch Pony
How to fix a broken tail
Call Hasbro Customer Service / Replacement Parts. Hasbro is out of stock on A LOT of stuff, especially the extras like carrots and brushes, but they may be able to send a replacement tail. If you have the tail and can see the break, it may be possible to fix, but you'll need a plastic:plastic epoxy (I can recommend). Do you have pictures? You can contact Hasbro CS directly at 1-800-327-8264 :)
Dec 01, 2011 | Hasbro Furreal Friends Butterscotch Pony
Furreal pony head clicking when moves
More information would really help :) Is this a new sound? The animatronics make S'mores sound like a middle school robotics project rather than a horse. It sounds like you should contact Hasbro's customer support at 1-800-327-8264 for their expert advice and response. :)
Nov 30, 2011 | Hasbro Fur Real Friends Smores Pony
My Kota Triceratops's neck is broken and she can not sing anymore. Still blinks, moves horns, wags tail and open and closes her mouth. No sound
The neck is not moving up it just stays down while he talks, blinks, and looks side to side;
any solutions?
May 03, 2011 | Toys
I am thinking of purchasing a faulty furreal pony - apparently it doesn't react to touch and the head does not move properly, making loud cracking noises when moving. Can this be mended and if so how...
all things can be fixed,,,at a price? why buy a broken toy? or have i missed some thing out here???
ok im a guy,,but iv missed the point of this,,,maybe thats what you get for being born a man,,
i was born stupid! ....look on e-bay one will turn up one day and i bet that one will work too?
Nov 28, 2010 | Hasbro Furreal Friends Butterscotch Pony
Hasbro fur real pony
http://www.hasbro.com/common/instruct/77422.pdf
Jun 02, 2009 | Hasbro Fur Real Friends Smores Pony
Furreal Pony neighs like a broken record
I had the exact same problem, and all I did was replace the batteries. It worked right again! I just knew the kids had broken the neck of it. It sort of slings to the left and neighs over and over again. BATTERY ISSUE :) The instruction manual should tell the consumer this. Hope this helps!
Dec 29, 2008 | Hasbro Fur Real Friends Smores Pony
Smores pony head stuck toward the left
Also check the screw that had the nylon cord attached to it. It could be stuck causing the head not to turn.
Dec 27, 2008 | Hasbro Fur Real Friends Smores Pony
Furreal pony, Butterscotch, Head floppy/leans left
There is a smaller "u" shaped spring in the middle of the neck mechanism that I found one side was snapped off. Looks normal, but it's broken. I made one out of a coat hanger for temporary purposes and it works like new! I will order one from Hasbro. Hope this helps!
Dec 09, 2008 | Hasbro Fur Real Friends Smores Pony
Hasbro Fur Real Friends Smores Pony Logo
599 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
