Question about Dell Wireless Keyboard Optical Mouse w0147
CANT ENTER MY PASSWORD TO GET IN MY COMPUTER KEYS NOT TYPING ON SCREEN ITS LIKE THE WIRELESS KEY BOARD IS NOT RESPONDING
    Scholar:
  • 106 Answers
My advice would be to put new batteries in the keyboard and see if that works, failing that, pick up a wired keyboard and mouse to log in to your system then re-connect the wireless set to re-install the drivers.
Posted on Jun 04, 2010
Cant download WIFI
you cant download wifi its an internet connection.!!
connection to wifi
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you.
If not you may need to turn on the wifi on those devices.
Usually those setting can be found in menus like Network Settings.
Once it recognizes the network you will need the password if it is required.
Just enter that in and you are set.
Where you enter the password is usually in the same menu in which you turned on your wifi enabled device.
if still no connection
Power on the laptop computer and wait for the operating system to boot.
Right-click the wireless Internet icon in the lower right corner of the desktop.
This brings up a new pull-down menu.
Select "View Available Wireless Networks."
This brings up a selection of different possible Internet connections that are in range of the computer.
Select the wireless Internet connection you want to use.
If a password is required, you need to type it in now.
Wait for the laptop to connect to the Internet.
In a moment the computer is going to state it has successfully connected to the Internet.
Click Start, Run type in cmd and click Ok to bring up a command prompt.
Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100.
Check your wireless connection properties under My Network Places.
Right click the wireless connection icon and choose properties.
From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked.
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
if still no joy
Let's first try to start the wireless service i.e. WLAN AutoConfig service manually.
To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok.
For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Aug 03, 2013 | Computers & Internet
How do i find a key for my linksys router?
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You should be able to see your present wireless network security key on this screen. You can also use this screen to change the key if you want.
If you want to make some changes first select the security mode you want to use.
I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless devices. After the first time they connect to the secured network they should automatically remember the security code. I hope this advice helps you out.
Nov 26, 2011 | Linksys Computers & Internet
How do i find my network key for my router lynksys wirelass wrt54gs
Nov 03, 2011 | Linksys Wireless-G WRT54GS Router...
Cant find wep key
If you have a wireless computer on your network and it is operating with the WEP key, then download and install this utility.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=mp-88884-1
Open the program and select "Start" it will do it's little scan and then when it finishes you should click on the Advanced Tools button. On the Advanced Tools page on the right+hand side, you will see a button that says Retrieve WPA/WEP Key, click on that.
If you do not have a wireless computer on your network, then you will have to find the WEP key in the router. On a computer that is plugged into the router by an Ethernet cable, go to Start, click on Run and in the Run window type CMD and press enter to bring up command prompt. In Vista and Windows 7, go to the Start Orb and type CMD into the Search bar, right+click on CMD in the pop up window and select Run As Administrator. Now that you're in command prompt type IPCONFIG /ALL and look for Default Gateway, that's your router's IP address, write that IP address down.
Now open up a web browser (firefox, internet explorer, Chrome, etc.) and type that IP Address into the address bar. Now your router login window will pop up, type in your login information for you router. The default login information for that router should be an empty username and
password = admin
Now that you're in your router, navigate to your Wireless>Wireless security page and right down the WEP key that is selected. That is your WEP key!
I hope this helps! If it does not, please comment back and let us know!
Dec 20, 2010 | 3Com OfficeConnect Wireless 11g Cable/DSL...
I cant find my wpa
Is your PC or Laptop is connected Wireless to Router, Follow this link
http://www.fixya.com/support/r5198336-details_router_or_network
If your PC is wired connected to the Router, try this
Click on START button
Click on Run ( you will find small window to enter command )
Type CMD ( or COMMAND ) and click OK button
( you will see black window on screen )
Type the command where the Cursor is blinking
IPCONFIG ( hit enter key )
From the list find DEFAULT GATEWAY
Default Gateway is IP address of Router
Open Internet Explorer
Enter the No. you find for Default gateway in the address bar ( without www or .com, just the no. ) - Click Go
You will find the Router page open
Incase if it ask you for username and password - type Username = Admin and Password = Password
Under Wireless settings / Advanced Wireless setting - you will find the WEP/WPA Key
Jul 06, 2010 | NetGear WNR2000 Wireless Router
Cant find my WEP for 2wire331
If your PC/laptop is wireless to Router - try this
OR
If your PC is wired connected to Router, try this
Incase if it ask you for username and password - type Username = Admin and Password = Password ( or the username and password which you have set )
Under Wireless settings / Advanced Wireless setting - you will find the WEP Key
Jul 01, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Cant connect wireless dont know network key (password)
you can find this network key or password or wep key, inside your modem configuration page. to do this.
1.use a pc that is conected to the modem
2. goto start then run and type cmd press enter.
3. type ipconfig and press enter.
4. the defualt gateway is like 192.168.2.1 or some thing like this. enter this into internet exploere or firefox adress bar and press enter.
5 you should be inside your routers configuration pages.
6 navagate till you find the wireless security settings.
7. look for wireless wep key.
this is what you need ot enter into your printer to conect to wireless network.
Nov 30, 2009 | Canon PIXMA MP600 all-In-One InkJet...
How do I get my WEP Key for my LINKSYS ROUTER
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your chang
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
Cant find my wep key, where can i find it.. please need help
goto start- run- type cmd & press enter.in the dos window type ipconfig press enter. whatever the default gateway is copy it. open internet explorer type that default gateway in address bar press enter.it will ask for user name and password.most of the time user name and password is located on the back of the router on the sticker.when you are in goto wireless settings.if you can read the security key then you can use it if not then you have to change the wireless key and connect all wireless computers again. hope that helps.
Jun 09, 2009 | Microsoft Broadband Networking MN-700...
Secure wireless internet
The D-Link is configured using a Web browser. After you have connected your computer to the D-Link router, follow these steps: 1. Launch your Web browser. Enter "http://192.168.0.1" into the address bar and press the "Enter" or "Return" key.
2. A logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
3. Click "OK". A D-Link configuration screen will appear. All changes to the D-Link configuration are made here.
Enabling WEP* (Wired Equivalent Privacy) will require anyone wishing to access the Internet through your wireless network to enter a password. After the correct password is entered, a connection is established, and all data sent from the D-Link to the computer and back is encrypted. From the D-Link configuration screen:
1. Click the "Home" tab.
2. Click the "Wireless" button.
3. Click the "Open System" button next to "Authentication".
4. Set the "WEP Encryption" to "128 bit".
5. Set the "Key Type" to "ASCII".
6. Type a 13 digit password into "Key 1".
7. Click "Apply".
8. When you connect to your wireless network from a computer, you will need to enter the 13 digit password.
*Note: If your computer's operating system supports it, enabling WPA-PSK is more secure than WEP. The steps above can be modified to set up WPA-PSK.
May 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Dell Wireless Keyboard Optical Mouse w0147 Logo
5,972 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
