Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
The mower starts, runs fine with brake depressed. When put in gear or blades activated stalls out. Possibly grounding itself out. where do I look either a short or problem?
  • vbks4597 Jun 05, 2010
    With the seat switch disconnected, is there supposed to be a "hot" point to test to verify power coming in to the switch. We used a circuit tester, but both points appear cold. We tried to trace the hot wire but no apparent cuts, crimps, etc. Is there a procedure to test the seat switch, i.e., bypassing that we are missing.
    its fixed!! it was the seat switch. For some reason even when sitting on the seat full contact wasn't being made. Manually depressed the switch all systems worked, as designed. We put a small screw in the plate to improve the level of depression of the switch. Lawn is now mowed...front.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
This is a symptom of the seat safety switch not working. Tilt up the seat, check the connection to the switch and also check the wires (pinched, broken?). The switch could be bad, or the mounting could have broken.
Posted on Jun 04, 2010
Why does my riding mower die when put in gear or engage the blades
Check out the grass box safety switch. if not fully depressed it will apply brakes to the blades when in gear. Most mowers are designed with a safety switch to stop the blades, or forward motion if the grass box is not fitted correctly.
Aug 23, 2015 | Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
Scotts 1642h riding mower Ignition Switch, Seat Switch or Wiring Problem?
Will run with no one in seat if clutch is depressed but will not run with clutch depressed and blade engaged with no one in seat. Could be your pto safety switch is bad. Maybe battery new but not charged try charging with 2 amp charger overnight and see if that helps. Maybe diode in charging circuit bad.
Sep 07, 2017 | Craftsman Garden
I have a craftsman 917.287030 and it will not stay running. i put it in gear and it stalls. any ideas??
Check the seat safety switch. For example, start the mower and then engage the blades. If the seat safety switch is faulty, then it will die. Same thing with putting it in gear and releasing the brake.
I hope this is helpful for you.
Aug 22, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Toro SS4235 with a 20 hp Kawasaki motor. Motor starts well, but when putting it into gear for forward or reverse, motor will die. One or more shutdowns must not be activated??? Occasionally it...
Hi gedallyn,
You mentioned that every time you gear forward or reverse the Mower's motor will just die.
I believe that you will need to check your gears and the also check to see the if the system is Running low in Fuel or possibly having a clog in the fuel line that can cause the machine to stop.
But still the issue is when you get it to gear forward or reverse, you may wanna check the gears first since that is the closes to your concern.
You can also check online at Toro for a user guide and info regarding you issue with this Link
I hope this help.
Have a nice day,
mvincentc
Jun 09, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My lawn mower will start easily and continue running as long as the clutch brake is depressed but when I lift the clutch or try to engage the blades while the clutch is depressed the mower will stall.
This is a shot in the dark. I think you have a failed "operator presence safety switch". Rule this out by finding the switch and jumping it.
Your mower should run with no one in the seat IF THE PARKING BRAKE IS SET.
If the brake is released and no one is on it, it should shut off.
If you are on it and the brake is released you should be able to engage the blades (probably an electric clutch)
Purpose of this interlock is the shut the machine OFF should you fall off or jump off the machine. Do not disable this valuable safety feature.
Let me know what you find.
Thanks for your question @ FixYa.com
May 15, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Starts fine,idles fine,stalls when put in gear to drive away
Try depressing slightly the gas pedal to see if the engine continues to run when you put it in gear. Might have to depredd gas pedal and brake simultaniusly. if the engine continues to run, then the problem is in the idle circuit. Try decarboning the throttle body and the idle speed control.
Mar 26, 2010 | 1989 Honda Accord 4 Door
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
131 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
