I have a set of RM300 Polk sub-sattelite speakers. Have had them for some time and still love em but.... The foam surrrounds on the bigger sattelites have disintegrated. Polk says too old cant fix. Really, isnt there some way to fix them. They just dont make them like this anymore.
  • 4,234 Answers
Yes they can be re-surrounded. It is not that hard, it just taes some practice. How big are the speakers? Look for a local speaker repair shop. They are few, but still exist. The hardest part is finding the correct surround. As long as the remainder of the speaker is in good shape, you will find these to be good as new once done. FIrgure about 2-3 days to complete the job properly.
Posted on Apr 09, 2008
I have a true sunfire sub and an onkyo 703 that has an rca connection for the sub. My question is do I connect my side channel polk 65's directly to the sub in jacks or directly to the reciever? If
The input jacks on the subwoofer panel are for connection of satellite speakers to it's crossover. The outputs are for the crossed over signal input to your receiver or amplifier, as there will be no amplification or channel processing from the subwoofer connection. It's only an optional crossover that may have a sonic advantage over the crossover in your receiver.
What you also can do is connect the speakers directly to the 703 and set the crossover frequency on it.
Dec 07, 2011 | Sunfire True Sub MK II Subwoofer
5channel amp 6 speakers how do i wire amp to speakers. channel 5 is a sub channel which i do not have my amp is a polk audio pa1100.5
if it is a 5.1 channel amp wire the center speakers together into the same port. wire the two front speakers in the or der that they would appear on the amp (such as left front speaker to the left front speaker terminal on the amp etc.) and do the same for the rear speakers. and all you should have left is the sub-woofer channel in which you do not have to worry about.
Jun 03, 2011 | Polk Audio Car Audio & Video
Optimum set up for Polk Audio PSW 10?
Run 2 RCA cables from the two Purple connections on your Receiver (Labled "PRE OUT SUBWOOFER") to the Red and White connectors on the back of your Sub (it does not matter which Purple connecter you plug into either the Red and White)
Set the volume control on the Sub to about 75%, and keep the power switch in the "ON AUTO" position. To set the Low Pass value, look at the back of one of the front speakers in your setup, and note its frequency range (will look something like 100Hz - 17kHz). Set the Low Pass at a value slightly higher than the low value on the back of your surround speakers.
To set the phase switch, stand in the middle of the room with some music on (something with some bass, but not over the top bass) and have someone switch between 0 Deg and 180 Deg. Listen for which setting sounds "Louder and Fuller". This is the one you want. You will need to do this each time you move the Sub, as its position may change its phase in relation to the rest of your system.
Good Luck!
Mar 26, 2010 | Polk Audio PSW10 Subwoofer
Sound went limp i think it the crossover
Define limp. No highs or no volume?
Logically, what one thing would affect both speakers? Logically, how would a crossover failure mute anything but the tweeter?
So, what happened just BEFORE this problem appeared?
I'd look at the electronics.
Feb 25, 2010 | Polk Audio R40 Speaker
New polk psw110 sub for rca rt2250 reciever
Hi there.
To answer your question;
There is no problem in using both subs at the same time. As a matter of fact you could split your signal in ten and have a sub for each one of them.
You`ll just have to set the subs levels so they match each other and i`d say the more sound to the larger sub.
Just try it at different sound level and you`ll find the correct setting.
Have fun Happy holidays
Dec 29, 2009 | Audio Players & Recorders
I have a HK 595 sub. with no sattelite cables.
you need the the satellite speakers hooked up in order for the sub to work. its not a standalone sub the volume control knob on the satellite speaker is what powers on the sub. i have extra speakers i wish i could give you cuz my sub just blew out.
Dec 20, 2009 | Harman Kardon HK595 Computer Speakers
Can n ot get rear surrround speakers to work
On this reciever you have rear surround and rear back spkrs, if your using the surr back they have to be assigned if unassigned in the settings. If using rear surr spkrs change your surr field to 5ch stereo and your rear speakers will work.
There is no 7.5 unless you have 5 subs the 7 is the total number of speakers and the .1 is the number of subs in the system
Feb 02, 2009 | Denon AVR-1708 Receiver
Polk Audio PSW 350 sub has no power
Hi, Just call the parts line at Polk Audio. They should have the fuse. You can also ask for technical if you're not sure of the problem. Here's the number for Polk: 800-377-7655 Good luck to you.
Dec 30, 2008 | Polk Audio PSW350 Subwoofer
How connect subwoofer to onkyo 8522
does it have speaker wire in and out use then from fronts
Feb 04, 2008 | Onkyo TX-8522 Receiver
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
73 people viewed this question
