Question about LG LSC26905TT Side by Side Refrigerator
My fidge wont despense water nor ice and it wont make any ice either
    Problem Solver:
  • 6 Answers
Check the water valve in the back of the ref
Posted on Jun 05, 2010
Water dispenser does not work. However, the ice maker does work so there is water availabe. Could this be a pump problem, if yes how do I replace.
It is not your pump, because despenser and ice maker both get water from the same pump.
Water despenser is activated by a small plunger when you press your water glass against it
to release the water. This is your problem, bad plunger.
Feb 03, 2011 | Amana ARS266ZBS Side by Side Refrigerator
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Dec 08, 2010 | Whirlpool Refrigerators
It despense water, but does not make ice
Either the water valve is bad or the icemaker is bad, assuming it is turned on.
Check the valve with the wires off with an ohmmeter.
If it shows continuity, the icemaker is bad.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Water just keeps pouring out of the top of the ice despenser
I would say your water valve in the freezer is locked in the open postion or has broken.
Jun 07, 2009 | GE GSH22SGRSS Side by Side Refrigerator
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
LG LSC26905TT Side by Side Refrigerator Logo
169 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
