Question about GPS
Have a Magellan Blazer 12 GPS Everything works except it stop receiving satellite signal. Can anybody help me?
SOURCE: Problem with Magellan GPS 315
I own Two Magellan 315. They both have failed in exactly the same way as yours, will not lock on too a satillite. I have concluded that this is their design life and that is the end. I did post one to the Magillan repair centre in France but that disappeared. I have replaced the two of them from EBay and will see how I get on with those
Posted on Jul 25, 2007
SOURCE: navigo sy885 not receiving gps signal
I had this with mine. remove the back of the gps and simply unplug the antenna re plug and try system. Worked with mine. Chris
Posted on Dec 16, 2008
  • 1111 Answers
SOURCE: magellan wont get signal?
charge the battery fully, then set it outside in clear view of the open sky. it may take as much as 30 minutes to acquire the sats if that fails, try and leave it out longer...does it appear to try and link to ANY sats. on the map screen in the top righ t corner is a icon with bars in it, tap that and you should see it trying to acquire sats. if not, you might have other problems
Posted on Jun 03, 2009
  • 12 Answers
SOURCE: GPS takes a long time to receive satellite signal.
You probably are just in a bad location where satellites are not reachable. All these units work from the same satellites and recieve them the same so it wouldn't matter what brand you have. I highly doubt that the powerlines and cell towers are effecting the transmission.
Posted on Sep 08, 2009
cvstan
  • 40 Answers
SOURCE: no longer receives GPS signal
Does this unit have an input for an external antenna? If you get/borrow another antenna you could see if it starts working. That might isolate the problem to the antenna.
Posted on Jan 23, 2010
No signal
Your GPS is defective. Contact Magellan for repair return instructions.
Nov 05, 2012 | Magellan Maestro 4700 Car GPS Receiver
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Magellan gps 315 will not connect to satellites
i have the same problem too, anyone has any idea. please share with us.
Dec 01, 2011 | Magellan GPS 310 GPS Receiver
Does not pick up satellite signals
The gps device is not receiving signal simply because the strength to receive signal is weak. What you have to do is to reset the gps device by holding the power button for about 15 seconds or there about, then you release it when the gps restarts. It will acquire signal after resetting the device.If it does not acquire satellite signal. You can also try to use the gps in an open space where the gps will be facing the sky, if it does not, then you replace the antenna of the gps device.
Hope this information helped.
Jan 01, 2011 | Magellan GPS 320 GPS Receiver
Magellan Maestro 3225 signal is no longer working. No satellite for navigation.
Look in the back. There is a small rubber cap on top of the external antenna hookup. Remove the rubber cap with a pin and hookup a long wire on the middle. That should amplify the signal.
Sep 13, 2009 | Magellan Maestro 3225 Car GPS Receiver
Stopped connecting to satellite
check battery condition also go into set up and see that the baud rate and port are set correctlyb in accordance with the manual.
Please rate my help++++Thanks for using FIXYA
May 20, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan RoadMate 700
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Oct 19, 2006 | Magellan GPS 315 GPS Receiver
GPS Logo
175 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
