Question about Refrigerators
Problem with auto defrost, so far I've replaced the defrost heater, defrost thermostat and control board. this worked for a while, now I have the same problem again. GE model GSS20IEPD WW. any ideas?
    Genius:
  • 1,073 Answers
Cintact ge some of these machines are under a ge factory recall for service preformed on them you need the serial number befor you call 800 386 1215
Posted on Apr 10, 2008
GE side-by-side not saying cold
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to temp setting .
May 26, 2010 | GE GSS22JF Side by Side Refrigerator
What if both sides of the refrigerator is not getting cold?And the back of the freezer side has frost.
Defrost problem. Either the defrost thermostat, defrost heater or defrost control board needs replacement. The defrost heater has to have continuity. The defrost thermostat has to have about 0 Ohms while it's cold. If both test out ok - replace defrost control board.
Part locations: Defrost heater and thermostat: under your frosted cover; control board - left upper corner of fresh food section, under the damper cover, in the middle.
Part numbers:
240554502 - control board
5303918255 - defrost heater kit
Can't find the part number for the defrost thermostat
Oct 17, 2009 | Frigidaire FRS26R4A Side by Side...
Not defrosting replaced defrost cencer still freezing up
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 17, 2009 | Refrigerators
My admiral fridge/freezer runs a lot but does not get down to temperature
Sep 14, 2009 | Freezers
Fridge never stops
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 11, 2009 | Kenmore 53082 / 53084 Side by Side...
Frige and freezer will not get cold .would vent in freezer being block cause this
No that would just affect the fridge.
Make sure freezer fan is working. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
Sep 10, 2009 | Refrigerators
Doesn't defrost,
Y
Aug 24, 2009 | Refrigerators
GE Model # DSS25PFMD WW, lights and fan are working not cooling
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
Refrigerator freezer is frosting up
Aug 14, 2009 | Refrigerators
Refrigerators Logo
271 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
