Http://www.givemefile.net/smanuals/projectors_home_entertainment/toshiba/tlp-b2.html
OK please find above, your service manual above, this will allow you to troubleshoot and repair your projector. This has much more information than the user manual, however you do need both. You may not have the correct sequence of keys? Or perhaps you may need to do it several times? Anyway please have a look in the service manual, this should help a great deal, and should help you fix it. Otherwise I suggest that you contact Toshiba support, and ask for a referral to an authorised service center, then contact, them, and ask for a 'Quote" for the repair, or even ask, to speak to the Service manager, and ask for advice with regard to your issue, you will often find they are very accommodating with help..
www.devicemanuals.com/.../Toshiba/Toshiba-TLP-B2-Projector-Owner's-Manual-TVRNNU56az.html
Thanks very much for this answer. The technical manual tells me what I need to solve this problem - which is the 'adjustment software'. The file name of the software is TLPB2S.EXE. I can't seem to find this anywhere online. Can you suggest somewhere I could source this software so I can finally solve this problem.......thanks again.....
The procedure you
followed to reset is not proper,
I will explain you the
exact procedure again:--
1) Unplug the power cord
from the electrical outlet.
2) Turn the main power
switch to the "On" position.
3) Press and hold the
"On/Standby," "Menu" and "Input" buttons at the
same time. Please note that the buttons are on the projector. Though the
same buttons are found on the remote control, the reset only works with the
buttons on the projector.
4) Plug the power cord
back into the outlet while holding the buttons in Step 3. The lamp timer will
reset when the projector receives power.
Thanks. keep updated for any more query.you can rate this solution
and show your appreciation.
Try this:
-Unplug the power cord from the electrical outlet.
-Turn the main power switch to the "On" position.
-Press and hold the "On/Standby," "Menu" and "Input" buttons (on the projector) at the same time. Without releasing the buttons, plug the power cord back into the power outlet.
THanks for your answer. As I said in my original question, I have tried this solution and it did not work.....
Your steps is showing turning the power off only and not unplugging the unit from power outlet.
My solution requires you to completely unplug the unit from the power outlet and the switch is ON. The ON switch and ON button are not the same. ON switch is the main power supply of the projector, ON button is the one on top of the projector, also used as STANDBY button.
Thanks - this did not work either. Any other suggestions?
Try this one. It works on some Toshiba projector but I haven't personally tested the process.
http://www.lampvision.nl/en_resetting_la...
Thanks for persevering with this. This solution does not work either. I don't think its meant for my machine which does not have numbers on the unit, the remote or the menu system. I have looked at every item on the menu system and there is no item that deals with resetting the lamp timer.....help:(
This works on other model but is not tested with TLP series.
Turn on your projector. When light on the projector is steady and ready
-PRESS and HOLD the "up arrow" on the REMOTE. Wait until you hear a beep (takes 30secs or more).
-As soon as you hear a beep, PRESS and HOLD "down arrow" on the REMOTE.
Wait until you hear another beep. (takes 30secs or more)
NOTE: beeps can be enable and disable in the projector menu. Make sure it is turned on or enabled.
Sorry - this didn't work either......
1. Turn-off
the device by pressing the "ON/STANDBY" and unplug the power
cord
2. In the meantime, hold down buttons "ON/STANDBY",
"MENU" and "INPUT and plug-in the power cord
3. The lamp
operation counter will automatically turn to zero
4. Check if the
lettering "0H" appears on the lamp operation counter in the
status display
5. After the lamp operation counter has turned to
zero, turn off the projector by pressing "ON/STANDBY" and unplug
the device.
ok
Reset the lamp counter hours of operation for the projector TOSHIBA TLP-T720
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord
3. The lamp operation counter will automatically turn to zero
4. Check if the lettering "0H" appears on the lamp operation counter in the status display
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
Other suggestions very welcome......
More help please - nothing is working so far.....
