Question about HP Pavilion dv5000t Notebook
A straight line on the side of the screen, and another line across the screen heading toward the mouse. Also there is a bunch of light lines like this: | | | heading toward the mouse.
    Scholar:
  • 113 Answers
Single Pixel lines indicate a failed Circut board in the screen. Although this being a DV series it could be a failed motherboard. You can test this by plugging the laptop into an external monitor and seeing if the artifacts you see are on the external monitor. If not, change the screen.
Posted on Jun 05, 2010
How do i set the timing on an 87' kawasaki 454ltd?
there are two flat head screw on left side side cover take them out one will have a nut to turn crank will looking in other hole turn motor till u seee a T with a line now the should be a notch in the threads of the hole u are looking through line the line beside the T with the notttch u see now with valve cover off u will see ether one circle or two straight lines one the gear attached to crack if it is one circle put that straight up or if two lines adjust them till both lines go staight (side to side) with the top of the head
Feb 11, 2014 | Motorcycles
Adjusting the headlight on 2005 roadking
Hi Anonymous, the correct procedure for adjusting a head light is as follows:
1. Verify correct tire inflation.
2. Place motorcycle on a level floor or pavement in an area with minimal light.
3. Point the front of the motorcycle towards a screen or wall witch is 25 feet from the axle of the front wheel.
4. Draw a horizontal line that is exactly the same height above the floor as the floor is to the center of the head light.
5. Have a person whose weight is roughly the same as that of the principal rider sit on the motorcycle seat. The weight of the rider will compress the suspension slightly.
6. Stand the motorcycle upright with both tires resting on the floor and with the front wheel held in straight alignment pointing forward.
7. Turn the Ignition/Light Key Switch to Ignition. Set the Light Switch on the left handlebar to High Beam.
8. Check the light beam for proper height alignment. The center of the main beam of light should be even with the horizontal line on the screen or wall.
9. Check the light beam for proper lateral alignment. The main beam of light should directed straight ahead i.e. equal area of light to the right and left of center.
10. The headlamp adjustment can be performed without removing the chrome ring. If the headlamp alignment requires adjustment use slots in the headlamp chrome ring to insert phillips screw driver between headlamp housing and rubber gasket. Turn the vertical adjustment screw as necessary to align the headlamp vertically. Turn the horizontal adjustment screw to adjust the headlamp horizontally. Good luck.
Jul 24, 2012 | 2005 Harley Davidson FLHRCI Road King...
How do you adjust the headlight on my harley xr1200
Hi Schnauzersru, the correct procedure for adjusting a head light is as follows:
Aug 20, 2011 | Harley Davidson XR1200 Motorcycles
11 black lines
your display is damaged so replace it . you have no other go
Aug 27, 2009 | Sony Ericsson W200i Cellular Phone
Canon MX700 printer - vertical lines aren't straight
Have you tried to do an alignment. Also check encoder strip
Aug 19, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Epson Stylus T10: Horizontal bands when printing cyan
With I could post a solutions but I have the same problem! Cyan has horizontal gaps, rest of the colors seem to be ok. I've realigned and cleaned the heads many times.
Mar 17, 2009 | Office Equipment & Supplies
1998 Chevy Tahoe Need an exploded view of the head light on the passenger side can't figure out where to start to change the bulb. Needs a high and low beam change but it's behind the battary and a bunch...
When you raise the hood if you look at the top of the light you should see two round bars. They are silver in color. Pull gently on these towards the front of the vehicle. when they unsnap pull straight up on these. this should release the light. Make sure you are holding the headlight so it does not fall.
Mar 09, 2009 | 1998 Chevrolet Tahoe
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
HP Pavilion dv5000t Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
