Question about Sony Playstation 3 (PS3) Console
No picture thru hdmi but picture thru RCA plugs
My picture stopped working with my hdmi cable but still works with the RCA wires. It is not the cable itself, it works on other components.
    Scholar:
  • 106 Answers
I had this exact same problem, or rather my friend did after I borrowed his PS3. You see when I borrowed it, the console configured the HD output to work with my TV, If this happened to you, there is a fix, With the HD cable connected, turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen. When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor. Once you can then get something on the screen, you can configure the video settings to match the TV you are hooking up to.
Posted on Jun 04, 2010
Cannot get the hdmi to work
My Tv won't recognize my computer when connected via HDMI [Solved ...
www.tomsguide.com/.../57797-4-recognize-computer-connected-hdmi
4 days ago - 43 posts - ‎36 authors
I too was able to get the HDMI output to work and then later on stop working. ... I'm also experiencing this issue, but still can't make the TV ... Audio over TV problem using HDMI cable
Jun 30, 2015
When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
My TV doesn't accept PC HDMI [Solved]
Dec 7, 2012
More results from www.tomsguide.com
TV won't recognize laptop when connected via HDMI ...
Dec 26, 2015 | Televison & Video
How can I make a NEC Plasma Monitor that was given to me work like a TV that has AUDIO?
If it has no internal sound, then you obviously can't make it function like a TV aside from the picture right? It does have inputs whether HDMI or standard Cable wiring to see TV from a cable box?
You'd need to have RCA cables coming from the cable box (Audio out - white wire I'd figure) going into a stereo near the monitor that has a VIDEO button on it where the white RCA cable is plugged into the Audio In jack.
A stereo receiver or even old sort of stereo with a Video or Auxillary sort of jack with button to activate that jack will allow for surround sound from the stereo coming from the cable box in sync with the video of the TV.
Feb 08, 2015 | NEC PlasmaSync PX-42VP5A 42 in. HDTV-Ready...
I Have my RCA CABLE HOOKED UP INTO MY TV I HAVE A PICTURE HOWEVER I DON'T HAVE ANY VOLUME AT ALL
How do you have it hooked up? RCA cables, HDMI, DVI, etc...
If you're using RCA cables (usually red, yellow, and white) check and make sure that the audio cables (red and white) are plugged into the correct sockets with corresponding colors. If you have properly connected the cables and your issue persists, then you might have faulty wires (might have a pinch which could have broken the wire through the inside) try again with different wires and see if it works. if it still doesn't work try pluging your RCA cables on different sockets (TVs usually have more than one component sockets)...make sure your red and white wires are on the same component # as the yellow wire.
Feb 16, 2014 | Emerson LC391EM3 39 in. LCD HDTV
Pioneer vsx521 stopped recognising hdmi connection from computer
Press the Audio Parameter button (Looks like an x) then scroll up until you see 'HDMI AMP' and hit over to the left or right so it shows 'HDMI THRU' the HDMI will redo the handshake and you should have sound.
Mar 12, 2017 | Pioneer Audio Players & Recorders
Have XBox 360 Elite and Voyetra Turtle Beach X11 Headset. Got new 3D HD TV and when I attached the HDMI cable to the XBox the headset stopped working. I have been told it is because the cable has an...
I myself have a 46" RCA LCD flat screen tv, which I have my xbox 360 connected via HDMI cable. If your tv has audio out "rca plugs", which im sure being a newer 3d HD tv, connect the supplied cable to the audio out (red, white) plugs, and then connect your headphones to that jack!
Dec 31, 2010 | Voyetra Turtle Beach Ear Force X11 Headset...
Video works, but no sound when connected with yellow wire. Also, when connecting HDMI cable i get no picture, only blue scree. Overall i have two problems, HDMI portion of the TV does not work, and...
yellow is for video only, please use also the white and red rca plugs for sound, hdmi problem could be a to high resolution choose 720p or 1080i in de connected device.
Oct 30, 2009 | Polaroid FLM-3232 Television
Powers on - no output to TV
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Console starts up and I can hear but shows no picture.
make sure video cable is plugged in all the way on back of ps3. the a/v cable is little tricky. it looks like its plugged all the way but its not. also if doesnt work, if u have hdmi cable use it then go to display settings, then connetions. set it up as av cable connection then it will ask about audio - av rca connetions. and save. now its set up as av cables and then when u use hdmi it will automatically set up hdmi.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
HDMI Port
you will have to look at the manual, but sometimes Audio isn't transmitted on HDMI cable,( I know it makes no sense). sometimes you will have to also use the digital optical audio cable, or SPDIF coax didital cable. I had to use the Di
As for your PS3 I had simillar issue, the PS3 doesn't Automattically adjust from analog, to component, to HDMI. If you get a signal thru the Reg RCA plugs, if you plug in the HDMI cable at the same time, then go to the system settings and change the type of plug you want to use, choose the HDMI, and the screen should flicker then show the signal from the HDMI, then just power off and/or unplug the analog cables, and you are using HDMI. hope this helps, if so thanks for the ratings
Mar 31, 2009 | iLO 3200 32 in. LCD Television
Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
Nov 08, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sony Playstation 3 (PS3) Console Logo
150 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
