Question about Hayward SAND FILTER, PRO SERIES
I keep getting earth in my pool from my hayward filter.I have a 15 x 24 ft oval pool I back washed it it starts at 7 and by 15 min its up to 15 and earth is getting in the pool any thoughts how i can fix this? thank you mary
    Scholar:
  • 78 Answers
You might have torn a grid or grids in the filter when you backwashed..
Posted on Jun 06, 2010
3620 hayward de filter earthe coming back to pool
take filter apart examine all the cloth elements if torn or ripped replace and that should fix your problem
Jun 23, 2014 | Hayward EC-40 DE Pool Filter with pump
Where do I find instruction manual(s) for Hayward Super Pump 15 HP SINGLE Speed W C17502 175 Sq Ft Cartridge Filter? Thanks
Copy and paste this link. It will take you to Hayward's main page, from there you can get any books you need.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1_13502_13502_I.htm
Nov 22, 2010 | Hayward Super Pump 15 HP SINGLE Speed W...
We have a hayward xstream pool pump for our 18' above ground pool that my daughter got through make a wish last august. we cleaned the cartridge yesterday and when we replaced the cartridge it started...
Try taking the pool filters cartridge out and following these steps to make sure that it is installed properly.
1. Clean debris from bottom of filter tank.
2. Replace element evenly on the collector hub in bottom of the filter body.
3. Place lid evenly on filter body and turn Easy-Lok™ ring clockwise until the safety latches engage securely.
4. Close and secure drain plug (located at the base of filter body).
5. Open air relief valve (Turn lever to left).
6. Open valves (Optional suction & return valves).
7. Prime and start the pump.
8. Once air has escaped the filter and a steady stream of water is flowing from the air relief valve, close the air relief valve and note the pressure gauge reading.
Jul 15, 2010 | Hayward Pool Products Hayward Xstream...
Pool filter return keeps stopping
If you have cleaned the fingers in acid you may have to replace the socks on the fingers.
Jul 21, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I have Hayward earth filter for the pool along with a Pentair Mini Max 100 pool heater - first time starting both for the season and the filter motor is making a straining noise. For the few minutes its...
make sure all vents are clean check to see if there is anything stuck in impeller with pump off take straner basket out look at opening going back to filter is water filling the strainer basket
Jun 17, 2009 | Hayward 1.5 Hp Northstar High Performance...
D.e. earth pool filter returning dirt to pool
The flow tubes inside the filter canister are torn and letting dirt pass. The repair is simple and can be done by someone with a few hand tools. Download the manual for the filter here:www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
You'll only need to replace the ones that are ripped, and the cost runs about $3 - $5 each. Search around on Google for a supplier or try a local pool dealer.
Jun 08, 2009 | Hayward EC-40 DE Pool Filter with pump
Water will not fill in pool pump
main filter blocked (try backwashing) or if using "earth" filter system - wash filters - change earth.
Jun 03, 2009 | Hayward 3/4hp Super Pump Inground Pool...
I have a brand new hayward filter for an in ground pool. The system uses D.E. The problem I'm having is after it's running for approx 30 minutes it looses all pressure. I've tried back washing it...
you might change out the D.E. media. you can also run it without any media to see if it looses the pressure after 30 min. mor than likely it is just time to change.
May 24, 2009 | Hayward Pool Products 55 Sq Ft Easy Clear...
Hayward SAND FILTER, PRO SERIES Logo
133 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
