Link Classic Model IRC81415 remote control to operate toshiba TV
Is there a code number to set or link my Classic Model IRC81415 remote control to operate toshiba 36ZP38B TV
cammykins
  • 149 Answers
SOURCE: Toshiba CT-852
A universal remote would cure this problem. It's generally since they are on the same system or IR codes are similar. There isnt much you can do to fix that problem unless you have a seperate universal remote to opperate seperately.
Posted on Sep 24, 2007
SOURCE: Code for zenith remote control for toshiba tv
I found the code
Posted on May 22, 2008
  • 8 Answers
SOURCE: rca universal remote control
Manual Code Search and Entry 1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality
Posted on Jul 28, 2008
SOURCE: agk remote controll
http://www.agknordic.com/new/index.php?side_id=76
manuals and code sheets for various remote models. fixed my problem..
Posted on Oct 19, 2008
SOURCE: Direct TV Remote Control RC64 Code for Insignia TV
http://www.fixya.com/support/t1555766-direct_tv_remote_control_rc64_code this worked for me after doing a GOOGLE search. 10150 is the code that even worked for TV power. Here are the other codes supplied, in case link didn't work, 10463, 10054.
Good Luck!
Posted on Sep 02, 2009
Need code for toshiba model 32df46
0285,0290,0259. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electromedicals.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 15, 2014 | Televison & Video
I have a Panasonic model CT-24SX10B tv with no manual or codes for the tv. I also have a old, but never used, Philips/Magnavox universal remote with no model number on the remote and no instructions or...
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
May 28, 2014 | Televison & Video
I have an older, but never used, Philips Magnavox universal remote (no instructions and no model number on remote. ). How do I program it to operate a panasonic model CT-24SX10B. tv? I also don't have...
0033 0049 0054 0075 0099 0101 0104 0107 0110 0119 0143 0151. These are the codes to check. . If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
I need the remote code for the tv: Toshiba 20af46c. Will a universal remote work with this tv?
0038,0032,0036,0030. Try these codes. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 21, 2013 | Toshiba 20AF46 20" TV
CANT OPERATE THE TV WITHOUT REMOTE, THERE IS NO MENU BUTTON ON HISENSE MODEL NO TC2199
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 16, 2013 | Televison & Video
Remote to an OLD Toshiba TV (model 37a33) is lost and I'd like to replace it OR possibly use cell phone for IR signal. Reason is I want to change video source but TV does not have button to allow it. Any...
If you wish to buy its original remote control, contact the authorized service center for Toshiba. If you wish to buy a universal remote control, check the code list to the remote control you do buy, have set-up codes to Toshiba TV. Setup codes to Toshiba are
1088 1077 1061
1070 1203 1423
1093 1466 1048
1213 1047 1141
1046 1231 1144
1276 1054
If you wish to get more details, check the sites linked here. It has setup code list and setup procedure to many popular brand remote controls. Check it, and find out which brand remote control have setup codes to your Toshiba TV, and buy that brand remote control according to availability. Brand name to a universal remote isn't a matter, but it should have setup codes to Toshiba. http://remotesearch.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 05, 2013 | Toshiba Televison & Video
NEED CODE FOR RCA UNIVERSAL REMOTE FOR DYNEX TV
This is the link http://remotefinder.rca.com/default.aspx?site=rca
You enter the model number of your remote control the product type and the brand. Dynex if it is not listed appears to be manufactured with parts from Toshiba and LG. There is a manual with all the remote codes at this link http://support.radioshack.com/support_video/doc66/66871.pdf but keep in mind that codes differ from remote control model number to model number. Hope this helps.
Apr 27, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Uneiversal Remote Code
The model of the TV is not important as the code list is by Make only and usually list 3 ot 6 codes to try for each make. Having the Remote control model number is more important so you can find the right instructions and code for your remote.
Check here
http://www.jascoproducts.com/support/universal-remote-codes.asp
Feb 18, 2009 | Toshiba MW20H63 TV
Toshiba ct-90233
Here is a link to your manual:
http://remotes.com/remotes/documents/Toshiba/CT-90233.pdf
Oct 02, 2007 | Toshiba CT-90157 Remote Control
Remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
