Question about Makita 18V 1/2"CRDLS Drill Kit
Replacing gears after removing chuck, how do you remove the gear box to replace it?
  • 34 Answers
You have to disassemble the tool completely. Remove chuck, remove battery, remove all screws holding body parts together, remove one side of body. Now you can see motor and gear box. Pull out both of them and twist gearbox a bit (just few degrees or millimeters) if it goes, then just pull gear away from the motor. Be carefull, some gear parts may drop of, so hold gearbox down and motor up. Juraj
Posted on Jun 08, 2010
My macita imp li-ion 18v chuck slipps
You may have a broken gear in the gear box or a broken output shaft. In either case you need to have it repaired or replaced.
Jan 21, 2015 | Drills
Chuck will only turn side to side after repair of gears box after
I need more information to answer your problem.
The chuck normally has movement turning because of the clutch gear.
It is possible if you had a gear strip or spindle break that there are pieces of metal in the grease that have jammed your new gears. I would recommend tearing down completely, remove all the grease, thoroughly clean gearcase, regrease & reassemble.
Nov 13, 2013 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Chuck broke on my hole hog how i fix it
The back needs to come off, you need to remove the spindle, press it off the gear, replace it by pressing the gear back on and reassembling. You will need to have your serial number then go to toolpartsdirect.com and look up the parts diagram. It looks like the part number is 38-50-5076 which also comes with a new chuck. I just looked at the kit as I actually have one in stock.
Aug 16, 2012 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
I have a makita BHP451 drill/driver with a keyless chuck and the gear box has striped out. I have a new gear box but do not know how to get the chuck off. I see a slot in the chuck that looks like you my...
The chuck has a left hand threaded screw inside. Turn to the right when removing the screw. Once the screw is removed you can remove the chuck by turning it to the left as it has standard, right hand threads. It is easiest to insert a large, L shaped allen wrench into the chuck, tighten the chuck, and hit the wrench with a hammer to spin the chuck off.
Jul 11, 2011 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How do I change the chuck on my milwaukee right angle 1/2" drill? It has snapped off behind the chuck
Take digital photos when taking the front metal gear box off the drill. Next carefully remove the two plastic halves of the drill if needed to gain access to the shaft that holds the chuck.
Replace the broken threaded metal part that the chuck screws onto.
Normally chuck replacement involves unscrewing the small screw deep inside the chuck on a metal shaft has a left hand thread. Next use a large allen wrench tightened in the chuck with a mallet to loosen the bad chuck. Reverse to install new chuck.
Feb 01, 2011 | Drills
Milwaukee cordless drill 14.4 gears
usually you would remove the chuck first under my name in the profile section is the tip for chuck removal, it is a standard thread probably 1/2-13. As far as the gears go try the site Milwaukeetool.com and type in your model number for a parts explosion. Let me know if I can help further
Oct 29, 2009 | Milwaukee Tool Drills
I have a hilti TP800 that will not hammer. no polunging action for the chisels
TP800 are that takes me back. right hear we go...
as over people have sugested remove the 4 screws and the black plastic cap from the top of the machine. you should be able to see the con rod and the crank gear, and in front of the crank gear you should see the small gear which is the top of thr armature, you may have to scoop out some grease in order to see it. Check that the con rod is not broken. earlier machines had aluminium cod rods but the later models have plastic ones which were prone to breaking. this isn't to say that the aluminium ones never broke because they did and wow what a mess may made when they did. if your con rod looks ok, try this... keep your hands clear of the open gears, and put some glasses on. turn the machine on and make sure that the crank is turning. look at the small gear on the armature to see is it is wobbly. the small roller bearing at the top of the armature use to callapse causing them to wobble. this would strip both the gears. a good sign of this is metalic parlicles in the grease. this fault is very expensive as you will have to replace the armature, bearing, seal, and the crankshaft. ouch...BUT DONT DESPARE. if this looks ok, it must be the piston rings these are cheap, fairly easy to change and available, as they are still used on more current models. the part number for these piston rings (o-rings) is 13772. want to know how to change them?.. read on...The hardest part is removing the chuck as you must remove the retaining clip at the tip of the chuck. hilti make a special tool for this, but it is possible with a good set of circlip pliers, 2 flat screw drivers and 4 hands. top tip...Remove the rear handle assembly, just remove the 4 screws and pull it off, now the machine can be stood upright on a workbench. Wear safaty goggles and put a chisel in the chuck, this will help you not to loose the clip when it flies across the workshop, I hate it when that happens. once you have the clip off its easy from now on. and don't worry, there is an easy way to get it back on. ok, the clip is off. remove the washer and the plastic chuck cover. remove the circlip, remove the chuck sleeves, dont loose the 6 balls or the roller. now there is another large circlip which holds on the black plastic cover. remove them both. now you can see the 6 bolts which hold the machine together. remove them. remove the chuck.you will see a large o-ring around the cylinder, remove it. Now with a screw driver carfully split the cylinder at the point where the o-ring was sitting. carefully pull out the inner cylinder. dont loose the small plastic balls. if they fall out dont worry. put them to one side. inside this cylinder you will find the follower piston, just tap the clyinder on the workbench and it will fall out. replace the o-ring, smaer with grease and replace. The drive piston is probably still inside the red casing. Simply pull the con rod off the crank and tip it out of the casing. on early models this piston had 2 seals. 1 teflon ring over a green rubber O-Ring. on later models these were replaced with an o-ring, the same as the follower piston, the earier type may not be available in which case you may have to replace the pison as well in order to fit the newer o-ring system. once the seals have been replaced, smear with grease. place the piton inside the cylinder just far enough so the conector pin cant fall out of the drive piston. Replace the plastic balls into the detents in the cylinder. use grease to hold them in place. Replace the cylinder into the caseing but make sure that the cut out at the end of the cylider is facing down. This is where the armature gear sits. as you push the cylinder in ensure that the con rod is hooked onto the crankshaft. reassemble in reverse order. use grease to hold the chuck balls and roller in place. dont fit the rear handle yet..now for that clip that caused all the pain at the start of the job. PuT YOUR GOGGLES ON. stand the machine upright on the workbench and get somone to hold it. place the clip on top of the chuck body tube. get a block of wood and place it on top of the ring, and hit it with a hammer. this will knock the ring on 80% of the way, now tap it on with the hammer. refit the rear handle. your done,,,if you removed all the grease replace with a similar type. 70 grams (3 oz) in the crank case under that black plastic cover..
Well I hope that helps, its not as bad as it sounds.
good luck.
please leave feedback .
if you have any more questions please email me.
if you want a parts diagram i can email you a drawing of a TE804 which is virtually the same machine with a slightly different chuck.
paul@wysehire.gi
www.wysehire.gi
Oct 08, 2009 | Hammering
Dewalt Drill DC728. Chuck came out of drill body
I would clamp chuck in vise and use a chuck key or a Channel Lock Pliers to loosen the chuck.
Jun 08, 2009 | Dewalt Drills
REMOVE CHUCK
The only way is with a special chuk key , and is not available to customers, if you still want to replace by yourself, you can by the whole gear case cover assemble that cames with the new chuck, but is is expensive.
Jan 08, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Makita 18V 1/2"CRDLS Drill Kit Logo
227 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
