Question about Friedrich QuietMaster Electronic SS12J30D Air Conditioner
The A/C is not blowing cool air
Just moved into a new apt 2 months ago and cleaned the 18,000 BTU a/c in and out. It's in a sleeve in the wall. I did turn it on when I moved in but it wasn't hot out. Today I finally decided to cool off the room. I let it run for at least 15 minutes and tried different settings. No luck. I believe it may just need some coolent. Before I call a repair person to check it out is there any advice so I don't get ripped off?
The Model # is KM18J30C-A. It's probably about 8-10 years old. The old tenants said it runs fine bfore they left. I think they lied to me.
I would appreciate any help. Thanks, Charlie
  • Chahoud Jun 05, 2010
    In your advice you gave the wrong Model #, therefore I think this is computer generated answers. Lets see. After more experimentation I notice when I turn it on at low cool I feel the cooler air and hear the compressor, just momentarily, for about 10-15 seconds. Then it's just the fan. WHat have you got to say now?
  • 6,826 Answers
You can tell if freon is needed ,if you feel the coil,near the filter,all over,if it is not getting cold all over after 20 minutes of running,then it needs freon,make sure the coils are not dirty,and stopped up,before checking the evaporator (the one inside near wear the filter goes)
Posted on Jun 04, 2010
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
I have a Emerson Quiet Kool Model # 12JW42K that is 13 years old. It doesn't seem to cool the apt. anymore. I assume that it would be smarter to get a new "energy saving" unit than invest in...
I know that a Island Air units come in all shapes and sizes and they make a ton of different units. They are made in new york thats who I would use. I would definitly go with the 12,000 btu unit 500 square feet needs 12,000 btus 10,000 is under sized. 500 square feet divided by 500 = 1 ton of cooling. let me know if I can further assist.
http://www.islandaire.com/
Jul 23, 2011 | Heating & Cooling
FAC122P1A I have a small 2 bedroom apt. maybe 700sq. ft. with bedroom doors closed the unit isnt cooling apt. as well as it did even a couple of weeks ago. The unit is blowing cool air but not enough to...
This unit probably need to be cleaned. Im in St. louis MO and its above 100 degrees with a heat index of 116 if your area is experiencing this kind of heat as we are there may be nothing wrong at all A/C units are designed up to 95 degrees when it get hotter than that the units never shut off till night fall.
Jul 21, 2011 | Carrier YC273D Air Conditioner Window/Wall
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
Replacement of window unit
Yes,you can,they are basically the same,you can get a 18000 btu to go in it.The more the btu`s,the higher they are anyhow.
Jul 22, 2010 | Heating & Cooling
Need the BTU rating for an old Kenmore K948991 a/c
Your model number is not complete enough for a model check.
However, 18,000 btu in todays' units is what you need.
Mar 28, 2009 | Kenmore Heating & Cooling
Ac not working like it used to
Storing the Unit is important -it should be up-right NOT on it side, this will cause the iol to clog the lines, NOT COOLING properly could be it need a good cleaning ( with a cleaning agent and a hose ) . to do this you have to remove the case or from the sleeve, BE CAREFUL NOT TO WATER "ELECTRICAL PARTS, clean drain line ( condensation "water" will cool off the ouside coil ( candenser) the inside coil can frost up if dirty or filter is clogged.
take the Unit out and clean well. you can purchase a spray that will remove all the grease and dirt - be careful not to bend tubing. use a light spray and let it dry in the sun. When putin Unit back in the window or wall WATER MAYBE SPRAYED OUT -DON'T STAND IN FRONT OF THE UNIT - IF you can't do this, call a serice company - this job can be done in a back yard.
EM
Aug 19, 2008 | Kenmore 72055 Air Conditioner
Trru the Wall Oversized
Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Oct 08, 2007 | Kenmore 75180 Wall/Window Air Conditioner
Friedrich QuietMaster Electronic SS12J30D Air Conditioner Logo
190 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
