Question about Miele Novotronic W1918A Front Load Washer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine seems to fill normally for the 'wash' phase but after it has been filling for a few minutes during the 'rinse' phase, the water pressure light starts flashing and, after some time, the machine shuts down (without completing the first rinse) with the timer resetting to zero. At this point the drum is filled to a depth of about 1" to 1.5". I know there is sufficient pressure to the cold water supply valves (there are three separate valve coming from the cold water supply) because the other valves which individually supply the 'pre-wash' and the 'second rinse' (fills through the starch dispenser in the 'separate rinse' cycle) fill the tub very quickly -- and with much more pressure than the first rinse either in a 'normal' cycle or in the 'separate rinse' cycle. For the first rinse, the water trickles slowly through about half the holes that drain into the tray that holds the detergent for a regular wash. I have also checked and there is no water being supplied from the warm water supply valve during the first rinse of either any 'normal' cycle (including a 90 degree cotton cycle) or the 'separate rinse' cycle. Again, the hot water supply valve seems to work because it provides a strong flow of water while filling the drum at the start of the wash phase of a normal cycle. I think this could either be a faulty cold water supply valve or a problem with the eletronic control which is not requesting water from the warm water supply valve at the start of the rinse cycle. I would appreciate any advice.
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Posted on Nov 28, 2010
  • 708 Answers
Check supply water inlet filter at hose. If not there and considering this to be 120v ac solenoids remove wiring to each solenoid and run 120v jumper individually and check water flow if you get good stream from each know you have a control voltage problem.
Posted on Sep 25, 2017
  • roeb Sep 25, 2017
    Check supply water inlet filter at hose. If not there and considering this to be 120v ac solenoids remove wiring to each solenoid and run 120v jumper individually and check water flow if you get good stream from each know you have a control voltage problem. Have been reading other site post and these valves can be taken apart and cleaned but look for holes in diaphragm if so replace.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
I've been dealing with this problem too...seems worse when the ambient temp (and possibly cold water temp) is lower (machine in unheated garage). After ruling out clogged inlet filters, I've been manually adding water (2L soda bottle) at the start of the first rinse cycle when the red light flashes.
I think this is indeed a problem with one of the 3 solenoids in the 3-way cold inlet valve body: you have to have 3 separate water paths for pre-wash soap, main wash soap, and fabric softener trays. Hot water has only one valve because it is only used in the main wash cycle when appropriate; rinses use cold water only, regardless. Unfortunately, the 3-way part is quite pricey from Miele.
The pre-wash and wash cycles go thru fine because the pre-wash valve is active both times. Rinse #1 relies on the bad main-wash solenoid alone...after that, I believe Rinse #2 succeeds because the fabric-softener path is also active.
This suggests a possible hack involving swapping out the bad main-wash valve with the fabric-softener one (or rewiring and swapping hoses to accomplish the same end). That will ensure the bad valve is only used once, in concert with a second good valve--ie, during Rinse #2. I haven't yet tried this, and don't know if disassembling and physically swapping the valves is feasible.
How to check a miele novotronic anti syphon unit
During rinse, water usually flows through the softener dispenser. The cup fills up and a small siphon tube triggers a siphon action
which pulls the softener and water into the washer. This siphon tube is probably blocked with crud. See if you can pull a small cap like part out of the softener dispenser area. Clean both the inside of the cap and the hole under it. This will allow the water to flow into washer instead of flooding.
Jul 06, 2016 | Miele Novotronic Premier 500 Front Load...
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
Aug 03, 2014 | Miele Novotronic W1918A Front Load Washer
Washer wont spin miele w1918
You can give Miele tech support a call, 800.999.1360, they can walk you through some troubleshooting and set up a service call if neded.
Jan 25, 2014 | Washing Machines
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Water leak
first you should open the unit and find out if the leak is coming from a hose or the pump or maybe a crack in the tub
Jul 25, 2010 | Miele Novotronic W1918A Front Load Washer
Water leak from front load washer - Frigidare GLTF1240A
just remove bolts, open bit enough to fill with silicone, close back wait to dry, ready to go for couple more years.
Apr 25, 2009 | Frigidaire GLTF1240A Front Load Washer
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rinse cycle water level
I would cheak your drein hose ithey should be higher then the tub of washer.If not remove hot and cold hoses from tap and washer and clean screens or get ne ones good luck:)
Apr 04, 2009 | Whirlpool CAM2752RQ Coin Operated...
Miele Novotronic W1918A Front Load Washer Logo
1,265 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
