Back to:
Tags:
Scanport 610A 14 in. Flat Panel LCD Monitor
Monitor shows "Out of Range" 60hz/85khz when... (by 2 users)
posted by KeyLime503 on Apr 09, 2008
ive tried reinstalling, system restore, this is the only game on my comp with this problem
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by salomon2123, posted on Jun 26, 2008
When I start up Guitar Hero the screen turns black and says "OUT OF RANGE" in the middle of the screen. I can only hear the sounds and music of the game but not see anything! Please help me! :(
Best Solution
posted on Apr 09, 2008
Helpful (85)
dileep007
Rank:Wiz Wiz
Rating: 84%, 503 votes
i think you must have tried to change the resolution to which your monitor frequency is not suitable OR this may also happen if you are not having any graphics card or AGP card so by this there will be a range of frequencies (refresh rates) which will not work...
so you must go to that game options and change the resolution(refresh rate) which is compatible for your system to work successfully ...
check system requirements for that game is it compatible with your system or not...
if you have the graphics card then adjust the settings correctly ..
if you dont have the graphics card then if you want to buy it then your pc must have a AGP slot or the PCI express slot ...
after inserting AGP card or graphics card you will be able to play the game ...
check your directx version also if it needs update ... latest is directx9c .. some games prefer directx9 and they also something like 3d compatibility,transform & lighting hardware ...
This and all options will be available if you have the latest graphics card ...
thank you...
bye
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Monitor shows "Out of Range" 60hz/85khz when starting up guitar hero III:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
Screen flickers and flashes. Then settles down for a few...
Monitors
hi dear, my computer works fine but...
Monitors
i have done this before connected me laptop to my moniter...
Monitors
Bro from where are you? got the same problem but finally...
I am looking for a power supply for this monitor. Can...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
