LG WASHER WD1260 SEVERAL PROBLEMS SOMETIMES WORKS PERFECT OTHER TIMES STOPS IN RINSE CYCLE THEN WE RESET CONTROL PANEL STARTS TO WORK SEEMS LIKE EXCESS WATER/SOAP STILL IN MACHINE. WE ONLY USE 1/2 THE AMOUNT OF SOAP. WHEN MACHINE STOPS IN RINSE ALOT OF SUDS STILL IN MACHINE. WHEN IT IS RESET WATER/SUDS COME OUT BACK OF TUB OVERFLOW/BREATHER AND WATER COMES OUT OF SOAP DISPENCER ONTO FLOOR
    Brigadier General:
  • 3,513 Answers
Hi
Since you have lots of problem in your machine I am trying to answer you one by one….
Check if the screws to the door hinges are tight and if any are missing. If it is so then it would not allow the door to be level and thus not be able to push the switch all the way down. This tells the washer the door is closed and if it is not closed it wont continue with the rinse cycle. Or maybe you are rinsing on cold water temperature and the cold side of the water valve is plugged up with sediment. If this is your problem, you can turn off the cold water supply and remove the hose end at the water valve side and clean out the filter screen that’s caked up.
For suds remaining in the machine it is cause the machine may not be draining and spinning due to a foreign object in your pump. For front loaders the filter for the pump is on the bottom right of the front panel of the machine.Turn the machine off.
Take the round cover off the filter by levering the top section of the cover.
Turn the filter so that you can remove it. There may be something stuck in there. Ensure it is clean and free of debris.
You will see the propeller type part that sits behind the filter, give it a little turn to ensure it is turning freely.
Replace the filter securely and the cover.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder). The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunges in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunges, blocking some of the water holes, it could be causing problems.
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
Posted on Jun 05, 2010
Why won't my front load washer fill in wash cycle unless I use rinse/cycle first?
either the motor brushes are worn most probable or the outlet presure switch has an issue {used to see if there is water still in the drum by the control logic}
Nov 28, 2014 | Washing Machines
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
It stops mid cycle and at the digital display it flashes " LE " . What is wrong????
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Apr 11, 2011 | LG WM1812C Front Load Washer
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
The selector for the spin cycle intermittently does not work
Yes. It is a timer. A lot of time though, the washer stop because the lid control switch is open. I means the washer has a sensor to stop when the lid is open or when the spin go widely unbalanced. Sometimes this sensor is too sensitive to vibration and stop the machine. The switch is in the back just behind the timer.
Jul 21, 2008 | Amana ALW480DA Top Load Washer
Buttons not working on lg washer
Sounds like the display board has a malfunction in the button controls and needs to be replaced.  Call a qualified LG tech to have it replaced and that should take care of the problem.
Apr 24, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
