Question about Denon Audio Players & Recorders
Denon UD-M31 - just replaced the laser and wire strip - still won't play...any ideas ?
SOURCE: Denon UD M31 CD not playing
It is possible that the laser has gone, the part you require is:
Sanyo SF-P101N CD Mechanism - 16 pins (there are 15 pin versions available which have the same product number, the two versions are incompatible)
i have found the part on Ebay (UK) for less than £5, the shop that sells it also suggest replacing the flexible strip that connects that mechanism to the circuit board, the strip costs £2 and replacing it would seem to be a very sensible idea seeing as you have to completely strip the unit to replace the mechanism.
My UD-M31 is in bits on my work bench at present, awaiting the arrival of a new mechanism, i'll post again if replacing it solves the problem.
Posted on Jan 26, 2009
SOURCE: setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Posted on Jan 28, 2009
Grubhead
  • 5397 Answers
SOURCE: CD JUMPING
Try looking into the lens (power off) with a magnifying glass. If you see any damage you will need to replace the lazer/lens section as the lens will never be able to read the disc.
If it's clear it's more likely to be an electronic fault.
Posted on Aug 28, 2009
  • 1121 Answers
SOURCE: Denon CD receiver - Auxiliary function not working
this is front headfones nearby cd player control knob
Posted on Nov 22, 2009
techman007
  • 1112 Answers
SOURCE: DENON UD-M30 CD Player is
HI:
Usually when a receiver goes into protect mode, there are several reasons, One is there is a bad speaker connected to the unit, this will cause the unit to to into protect mode, try disconnecting all speaker from the unit and turning it on if it does not go into protect then one of the speakers are bad. Another reason is the power output Amplifier IC is shorted inside the unit. Another reasons could be that speaker wires are touching each other and causing a short. Disconnect all unit connecting to the unit and try turning on, if it stays on and no protect then connect them including the speakers one at time until you determine which is causing the error. If it goes into protect with nothing but the unit on then the Output IC is bad and the unit needs servicing.
Posted on Mar 10, 2011
How do I connect my tv to my UD-M31 - Denon CD Receiver
The receiver must have an optical "IN" port to be able to connect the TV to it.
Dec 07, 2016 | Denon Audio Players & Recorders
Denon ud m31
Get the manual and read it.
Aug 05, 2013 | Audio Players & Recorders
Denon D-M31. It's had a problem for a while where after a minute or so the volume control on the front works very intermittently. The remote control volume contro; still works fine though. I have heard...
Hi. It's called a rotary encoder.
You might get a replacement from Denon if you have soldering skills or can find a part number in the service manual. I'm unable to access the site just now:
Denon UD M31 Manual Compact Disc Receiver HiFi Engine
Jan 18, 2018 | Denon Audio Players & Recorders
Denon seperates
The most likely cause of this problem is the laser is becoming weak. You may be able to get a bit more service out of it by manually cleaning the laser with a cotten bud and some alcohol. However the only real solution is to replace the laser assembly.
It depends on how good at taking things apart and putting them back together you are, weather you should try this yourself. The laser assemblies often have the part number on the side of them, if not you will need to contact Denon who may tell you what it is if you are lucky.
Almost all laser assemblies come fully clibrated and all you need to do is remove the old one and replace it with a new one. You can get the parts from CPC in the UK unfortunately I don't know about other countries.
Regards, Andrew
Sep 14, 2008 | Audio Players & Recorders
After lightning strike, my denon ud-m5 displays "protected" when trying to play fm and doesn't work.
Check the wire at the back of the FM Ant. If possible replaced it or relocate the FM wire.
Good luck
Jul 28, 2008 | Denon Audio Players & Recorders
Denon UD-M31. Circuit protect mode permanantly engaged.
Sounds like the output section is fried. See a repair guy.
Jun 02, 2008 | Denon Audio Players & Recorders
Jan 01, 2008 | Audio Players & Recorders
Subwoofer
what do i need to connect a subwoofer to my Denon UD-M31
Nov 15, 2007 | Denon D-M31S CD Shelf System
158 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
