Question about Canon PIXMA MP160 All-In-One InkJet Printer
Top 3/4 of page prints but last 1/4 dosen't. Is it my ink jet or do i need to change the ribbon? Ink is fine for the ammount that prints.
  • 71 Answers
Go to the control panel, go to printers and faxes, click or righ click on your printer, choose printer preferences. Check the paper size. It should be set to A4 or letter
Posted on Jun 05, 2010
How do you change ink ribbon/cartridge?
It's the ink roller you need to replace - it's on page 3 of the user manual (attached link to it). Canon P23 DHV User Manual Page 3
Jul 12, 2016 | Canon P23-dh V 2 Color Mini-desktop...
I am printing 3 pages the print on the pages are faint in two of the 3 pages. It is not low on ink because it prints the last page just fine. It's faint like its out of ink but it is not out of ink . ...
Squeeze a running garden-hose, and the water will spout out, but at a diminished rate.
If your printer has "nearly" clogged ink-paths, then the first page or two will be diminished, until the ink "washes" the walls of the ink-path, to finally allow more ink to flow through than on the first page(s).
Use the HP "Printing Assistant" software to run a "print-head-cleaning" cycle, to try to "unclog" your printer.
Dec 01, 2010 | HP Deskjet F340 All-In-One Printer
Not printing the top half of letters on HP OfficeJet 4680 printer
Well, this can be an almost entry print cartridge. Or a clogged print cartridge. Or a broken wire that connects to the print head so that it does not work the top half jets. Or a bit of dirt or stuff on the pad that connects the cartridge to the print head.
1. Remove the cartridge, and blow the area out with canned air. Shake the cartridge, both to redistribute ink and to verify the presence of ink.
2. Examine the ribbon cable that connects the cartridge to verify that it is intact.
3. If and only if you can't find a problem in the above, (or if they are empty) replace the cartridges.
Feb 01, 2010 | HP Office Equipment & Supplies
Print is faded. I just replaced the ink jets.
You said you just replaced the ink jets. Did you clean the print heads? Here is Link on Web. If you find this helpful pls rate me. Thanks
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality
Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print
head. You can start the cleaning process manually if needed.
Clean the print head and ink cartridges if you get a horizontal line in
the text or graphics on your printed pages. You can clean Black only
or three colors at a time (Cyan/Yellow/Magenta), or all four colors at
once.
Cleaning the print head consumes ink. Cleaning too often uses ink
unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause
permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service (see Brother
numbers on page i).
Jan 11, 2010 | Brother MFC 210C All-In-One InkJet Printer
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Chews up paper while printing then jams paper.
Top loader or bottom loader? Ink-jet, dot-matrix or Laser? All have different reasons. Most common are ink-jets. Most common are top loaders. Most common cause is cheap paper. Buy ink-jet paper. Most people buy cheap copy paper (20#). Buy a good 25# or heavier paper to keep that from happening (especially w/ top loaders). People always worry about that extra dollar or two for paper, but it take an average of 10ml of ink to print 300 pages. That's 1 cartridge ($10 to $20 dollars) for less than 1 package of paper ($3 to $5).
how to clear paper jam: http://www.ehow.com/how_113761_clear-printer-paper.html
Apr 05, 2009 | Office Equipment & Supplies
Service error 5600 appeared when the printer stop
Dear budg,
Error code 5600 in S200 is No Print head Error indicator. In this case, the print head of the printer is faulty so that the printer cannot detect the print head. About the print out, please check if there is enough ink in ink tank to print. If there is enough ink to print, means this bad print out caused by the faulty print head. It seems that you to replace the print head.
Regards,
Dec 02, 2008 | Canon S200X Ink-Jet InkJet Printer
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
Oct 08, 2008 | HP DeskJet 920c InkJet Printer
First Page Problem
Since you have changed a cartridge, you need to do some maintanance. First, try an allignment. It should be in your printer's included software. Try printing the page agian. If it doesn't work, then try cleaning the head. Again, this can be found in the included software. There should be a few levels. A test page is printed each time. You might want to try more than the first level, but each level onward uses more ink. Lastly, you might want to get some help from the manufacturer. If you got it refilled, then you should check with them.
Hope this helps.
Eric
Jan 29, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
