Question about Electrolux Kenmore 30 in. Gas Freestanding Range Range
How do I reset my oven? I keep getting f31 when I
What does F31 means when I turn on my oven? do I need to reset? If so, how? Thanks
  • cyndegrammie Jun 04, 2010
    Actually my oven is a Kenmore white w/Blk 30" self cleaning freestanding model 7853
5 Suggested Answers
SOURCE: f31 code for kenmore oven
Hi Jim,
I have the exact same problem on my Kenmore oven. Did you get any help as to what it is? My email is orenj10@yahoo.com
Thanks,
Oren
Posted on Mar 03, 2008
aborcass
  • 2651 Answers
SOURCE: oven not turning on f31 code kenmore
may be a real simple , lets try this. unplugh the unit, and uscrew rear panel of the unit, there is a thermostat that may have tripped, very small maybe the size of a quarter, with 2 wires on it, easy to sppot because it will have a small red button atop of it, its resettable, so if it did "trip" melrey reset and your on your way,there are actuallly 2 of theese thermostats on your unit, and actually a more common one to trip would be the one in the control panal, so id prblaby check this one first, to acces it remov eht knobs, then wehere the knobs were are "large plastic lock washers" holding down the control panel, one around earch knob opening, after ermoving htem the control panel will lift up and lean over. i belive there are 4 screws to remove the clock(plenty of slack in wiring no worry)after thats out of the way, if you look down under behind the switch to right is the same resetable thermo(lok for the the red button) and with a small long screw dricer youll be able to reset it, this should cure you issue. sounds like a ton of directions but should take no maore than 20 min, to check em both
Posted on Dec 30, 2008
  • 1416 Answers
SOURCE: Kenmore model 790.7851 gives an F31 error code
hello,
The F31 is an error code indicating that water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you have to do to fix up this is to unscrew (open)ranger then trace the wire down to the reader sensor/panel clean all form of water and dirt around them after all this make sure that all wire are in there position mostly on the panel then couple it back as it was with this the problem of F31 is solve please do this with care
thank you.
Posted on Jun 13, 2010
  • 5 Answers
SOURCE: code f31 shows when try to turn on oven
F31 means there is a short in the oven cavity probe circuit. The probe is the one of easiest things to replace. But this could be a control as well. To start, remove power from the range, unplug it. Remove bottom backguard panel, look for two purple wires leading down to a small white connector, which will lead you to a rectangle piece of metal (approx 1 X 3/4in) with one corner tucked in the body and a screw on the other end. This will be located on the right hand side of the back about half way up. Once you remove the screw, twist from the corner, slide out gently. http://b2b.frigidaire.com/support/manuals.asp?user=&NewSearch=New+Search will provide documentation for a part number for the "probe" or may be called "RTD."
I would be glad to provide more detail if you like, I would need more details in return...
Posted on Aug 30, 2011
What does F31 mean on Frigidaire stove?
Thank you for your inquiry, friend!
Based off what you have described your Frigidaire range is displaying an F31 error code and you would like to know what it means. An F31 error code means a shorted probe connection. This could be a possible problem with your sensor probe, control panel, or probe connector. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue you may need to seek help from a professional technician for proper diagnosis and repair. Best of luck! -Matt
Aug 12, 2015 | Frigidaire Kitchen Ranges
/lfgf3014lbcwhat does f31 mean
Hello Jim, thanks for your post!
From my understanding your Frigidaire range, LFGF3014LBC, is displaying an error code of "F31". The "F31" error code stands for a shorted probe connection which could be an issue with your EOC (Electronic Oven Control), wiring harness, or RTD (Resistance Temperature Detector). I would suggest performing a reset on your range to help clear out any false error codes. You can reset your range by flipping off the household circuit breaker for ten minutes. I hope this information is helpful to some degree. -Matt
Mar 30, 2015 | Frigidaire Gallery 30" Self-Cleaning...
What does f31 error mean on fregidare gas range
Good Morning friend, thank you for your inquiry!
From what you have described your Frigidaire range is displaying an "F31" error code. An "F31" stands for a shorted probe connection. This could be an issue with your RTD (Resistance Temperature Detector), EOC (Electronic Oven Control), or wiring harness. I would recommend performing a reset on your range to help clear out any false error codes. In order to reset your range you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue and you continue to receive the error code you may need to have a professional out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
F31 on my Frigidaire oven how do I fix it?
Good Afternoon friend, thanks for your post!
Based off the information you have been able to provide an "F31" error code stands for a shorted probe connection. Typically this means you could have issue with the RTD (resistance temperature detector) sensor probe or the wiring harness between your control panel and probe connector. Since it could be any one of these under lying issues I would recommend a professional come out and properly repair your appliance. Hope this helps. -Matt
Sep 17, 2014 | Frigidaire Kitchen Ranges
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Mar 30, 2014 | Bosch HBL 455 Stainless Steel Electric...
When I try to turn on oven the code F31 shows
Hi and welcome to FixYa,
I am Kelly
See this link:
http://www.applianceaid.com/faultcodes3.html
Scroll down past mid page and read F31
Your Temp probe is shorted. It shuld read around 1091 Ohms (+or- 5.3 Ohms) at 75 Deg.
If you respond with your model number I can point you to parts sources.
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Frigidaire Kitchen Ranges
I have an error code F31. What does this mean
f31- suction pressure protection. Short gas or no gas. Check for leak and rectify.
Nov 14, 2009 | Panasonic Room Air Conditioner CWXC104HU
F31 error
it is a shorted oven probe sensor
Apr 09, 2008 | Ovens
Electrolux Kenmore 30 in. Gas Freestanding Range Range Logo
283 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
