Question about Goodman CLQ36AR49 Air Conditioner
My air conditioner doen't start. I have a goodman air cond.
    Scholar:
  • 45 Answers
Check to make sure that the power is on to the outdoor unit and the furnce. Check breakers and fuses. There may also be a disconnect outside located by the condenser. It is probably a gray box, loft the cover and make sure the shitch is on. Otherwise if you turn the thermostat to cool, if the furnace blower comes on and the outdoor unit does not check the following. Turn off poer to outdoor condenser and open up the electrical compartment on the condensing unit outside. There is a round or oval cylinder inside. Its probably silver in color. That is the capacitor. If the top is bulged, its a true sign of a capacitor failure. Take the capacitor out and take it to your local HVAC Wholesaler of contractor. The part should cost you around 15 to 25 dollars. If this does not work, let me know.
Posted on Jun 05, 2010
Cond fan motor runs for about 10 sec then cut off
sounds like it is getting hot need get a can of conpressed air and blow it out.
Jul 30, 2014 | Goodman Manufacturing Goodman MSG18HWN1W...
I need to know what wiring diagram to use for SSZ140421 Cond with AEPF426016 handler with HKR15C strips.
The AEPF number is for an Amana air handler. I have a manual for this number. Send me an email address and I can forward it to you. Manual has diagram.
Oct 06, 2010 | Goodman CLQ36AR49 Air Conditioner
I have a goodman CKJ42-1B air cond. unit. It keep tripping my AC breaker although continues to blow air - just not cool air. Once I turn OFF then ON the breaker the AC works fine for about a day. Then...
try cleani ng the unit outside with your garden hose first .sounds like its kinda dirty .the dirty er the coil is the higher the amp draw is when it is running .what size is the breaker in the box .thats a 3 an a half ton condensor
Aug 06, 2010 | Goodman CKL36AR36 Air Conditioner
High head -suction 75 head 325. alredy cleaned evap coil and condenser
thats high head try cleaning the cond coil aging, and depending on the out door temp. was any thing changed the fan speed is right. or the unit is over charged.
Jul 17, 2010 | Goodman CLQ36AR49 Air Conditioner
2003 vw passat air cond blows warm air
Hi there. You have a freon leak in the system. You can charge the system and use soapy water on all joints to find the leak. If a slow leak, just recharge every year. This will get you by till you get the leak fixed.
Thanks
Paul
Jul 11, 2009 | Goodman CKL24AR24 Air Conditioner
Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Apr 28, 2009 | Goodman CKL60AR60 Air Conditioner
Switching from heat to air cond.
just move the switch i am sure it won't do any harm
Apr 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
105 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
