Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
How do I reset a Viewsonic N2759w to Factory default settings
  • ViewSonic Master
  • 5,103 Answers
On most Viewsonic TVs, hit menu (on the TV or your remote) go to Options (or Setup). The icon will look like a hammer with a double ended wrench across it (at least on my TV - a different model). Hit the down arrow and select Restore Default or Memory Recall. Select Yes and Enter when you see the prompt. Then exit the menu system (by hitting menu). The action is saved when you exit.
I hope this helps.
(the two different commands results from a change in Viewsonic's menu system - my print manual differs from the current on-line manual at Viewsonic's site. I'm not sure which set of commands will apply. If your TV menus are different, the names should still be similar.)
Posted on Jun 04, 2010
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
How to reset viewsonic vx2435wm
Usually ViewSonic products have a default memory as part of the OSD or menu system. Enter the menu by pressing the "1" button, then scroll down to find the default setting and execute it. If this doesn't resolve your issue, I recommend you call ViewSonic Customer Care for support.
Jun 24, 2014 | ViewSonic Computers & Internet
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
Screen got redish
Well you need to go to settings and reset it to Factory default settings it's still under warranty then contact the vendor for replacement or contact the customer service.....goodluck!
Jul 29, 2010 | ViewSonic VA1703wb Monitor
Looking for anyone who knows the reset for a ViewSonic VX2035WM?
Here are the spec, driver, user guide.
http://www.viewsonic.com/products/desktop-monitors/lcd/x-series/vx2035wm.htm
User manual: http://www.viewsonic.com/assets/012/6288.pdf
See page 12 of the user manual.
Press MENU button and selct 'MEMORY RECALL' Tto set the monitor back to factory default.
http://s807.photobucket.com/home/budm/allalbums
Apr 30, 2010 | ViewSonic VX2035WM LCD Monitor
Viewsonic N3250W- turns on, the screen flickers on then its black
This could be a problem with the tv's memory. Try resetting the TV. Unplug the unit for a few seconds (10-60). Then restore the TV to the factory default settings. Viewsonic has changed it's menus at intervals so you may have to check your manual. It may be Menu > Setup > Memory Recall or Menu > Options > Restore Default (or something slightly different). From there, click enter, use the right or left arrow to select YES, hit enter. Leave the menu system (Menu twice). Then hit Menu > Channels and rescan all channels.
An alternative cause of the problem may be a weak signal - check that your antenna is pointing right at the station and is the correct type to get the signal at the distance you are from the station. (Usually a weak signal would also have the audio breaking up but weird things can happen.)
I hope this helps.
(who recently had a channel pair that started out with flickering signal issues and then had one channel lose video and the other audio. The memory reset and rescan resolved the problem.)
Apr 24, 2010 | ViewSonic N3250W Television
Need to fine my key code
reset your router to the default settings
then check the user guide to navigate to the default ip and reconfigure the router
manual here http://www.la.viewsonic.com/pdf/userguides/wr100-1_ug_eng.pdf
Nov 08, 2009 | ViewSonic WR100 Router
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
2,064 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
