Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Aquarius WD420P has something stuck in its output hose
The water won't empty
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasheraquarius WD420P has something stuck in its output  - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jun 05, 2010
What does f-5 mean when flashing at me and won,t let me have my washing out the machine also washing really hot after a fast spin programme
if water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Jun 25, 2010 | Hotpoint Aquarius WD640 Front Load...
WMA54 won't empty water? We've emptied filter but
Could be the pump, but they do not often fail.
I would check the main hose or the pump itself for a blockage.
Try blowing down the hose to see if it is clear.
Mar 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Water is spilling out from d soap drawer and door area when washing machine is switched on.Its a hotpoint aquarius WT 740
if its a front loader, u have something stuck in the drawer hose inside. like a sock or clothing item
Feb 12, 2010 | Washing Machines
What kind of motor installed in hotpoint washer/dryer model No. WD420P
It is a brush type motor, rated at 1400rpm.
Runs on mains 240v
Trust this is the info you require.
If you need more info, e-mail me.
Thanks.
Dec 06, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint aquarius 1200 wont empty and I cannot find the filter to try and clean it out
HI. the filter is mounted on the drain pump housing. You will need to disassemble the unit to access the filter. Here are some other areas i would check, also.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious issue within the actual control sector(Timer module or control board). It should be replaced i this case.
Oct 25, 2009 | Hotpoint Washing Machines
Door locked and takes water will not empty or spin
turn the machine off and check under the lid.
the pressure switch hose may have fallen off. its a clear tube that fits onto a nozzle on the underside of a plastic circular unit about 40mm diameter on the left hand side. this should shut the water off when filled to correct level.
to get the water out in any case put the drain hose end lower than the water level into a basin to syphon it out. lifting the hose above water level will stop it till you empty basin.
Jan 30, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Hi, my hotpoint aquarius wma42 washing machine washes ok but will not empty, i have took the filter out of the back and cleaned it, but its still doing it. can you advice
Make sure there is nothing stuck in the pump, and that the outlet hose is not blocked or kinked.
If o/k , then you need to confirm that the pump itself is working
Select drain only. or drain and spin, and you should be able to hear the pump running, if you are satisfied that there is no blockage any where and the pump is running, but no water comes out,
Then fit new pump
Plz rate my solution.
Thanks.
Jan 16, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Noise when draining
U will find the filter by removing the lower rear panel of the m/c.
Locate the large black hose at the right side, and remove clip securing hose. Get some thing ready to catch any water that will be in there, and remove hose.
There u will see the filter, remove and clean, refit filter and hose,making sure that u get the hose on properly, test for leaks before u put the panel back on.
U will find this much easier to do if u tilt the m/c forward, and support it with something underneath.. Check inside the pump as well.
Thanks.
Dec 31, 2008 | Hotpoint WMA50 Front Load Washer
Tumble Dryer-empty water light won't go off
remove panel on rhs looking from back and you will see a chamber with a microswitch on top. either micrswitch is stuck, pump faulty or a lint blockage
Jul 23, 2008 | Dryers
Water will not drain from hotpoint WF620P
Ya need to find the water pump. It will have two hoses going to it. Pump may have a pen or someting stuck in it and wont let it turn. goodluck
Dec 16, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
147 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
