Question about Cameras
IT Works DSC 551 - power on issue
I have an IT WORKS DSC 551 camera..... All it appears to do is show the RED BUSY light for a few secs and then nothing... can anyone advise as to what the issue could be? I.T Works DSC551 I.T.Works DSC 551 I have a I.T. Works DSC551 camera and have not been able to load any pictures onto my PC. When you attempt to sewt the camera up on your PC you simply get a message back saying "The hardware was not installed because the wizard cannot find the necessary software" This is despite me previously doing a full install from the Install CD provided with the camera. The user manual is a complete waste of time and badly written and there is no link to any manufacturers website for hints and tips or service support. Very poor. Has anyone else out there had similar experince regarding this camera and any succesful outcome to resolving this isuse (or not).
3 Suggested Answers
SOURCE: IT Works DSC 551 - power on issue
I also have an IT Works DSC551 and I can't transfer my photo's onto my PC. It takes photo's normally but when I connect to the PC it acts as a Web cam. Please help. x
Posted on Feb 08, 2007
hello I have a camera numerical itwoprks dsc551 veiled of which I have a problem when I puts the piles and I it aalume it indicates busy in red light to me and then it etteint to give me the solution thank you
Posted on Sep 09, 2007
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Sony DSC T10 shows error E: 91: 01. Also flash
1. Turn OFF camera
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Your problem should be solved
Oct 31, 2009 | Sony Cameras
IT WORKS NOT
Red light busy implies.. its memory access signal.
Its not a problem. What happens after that. I guess it should be fine.
Sep 08, 2009 | Cameras
Flash symbol flahing with flashing number E9101 but does not flash only infer red light
Try this........
1. Turn OFF cam
9. Take some pictures
Hope it will solve your problem....
Oct 06, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
I.t. works dsc 551
i cant down load my 3045 3.1 megapixels
Sep 09, 2007 | IT Works It Shot 2070 Digital Camera
Aug 07, 2006 | IT Works It Shot 2070 Digital Camera
Cameras Logo
53 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
