Question about Brother MFC 210C All-In-One InkJet Printer
Not cleaning the ink
my printer is not cleaning the ink....whenever i switch it on it start saying unable to clean ink....
is there any solution to this prob or i have to rush to the mechanic....?
  • 1 more comment
  • babycool Apr 13, 2008
    brother mfc 7300c/mfc7400c printer
  • Anonymous Apr 23, 2008
    I have followed the manual instructions to unplug the printer for a few
    seconds. I have looked for bits and pieces of paper. None found.
    I have cleared all faxes. None found.
  • Anonymous Apr 25, 2008
    unable to clean
  • 832 Answers
Plz search unable to clean or error 46 the issue had been explained a thousand of times ;-)
Posted on Apr 09, 2008
What can i do to fix this prob?clean unable 5a?how do o clean it manualy?
Jan 11, 2013 | Office Equipment & Supplies
Unable to clean
Take out the ink and clean on a soft cloth the printhead and then try again to clean. If this doesnt work post to me I will instruct you further what to do
Please rate me good
Jul 14, 2010 | Brother DCP 115C All-In-One InkJet Printer
Printer keeps saying can t clean ink
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box!
Jun 05, 2010 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean????
Were you told to,
1.Clean the jet holes on the ink cartridge, and
2.The area on the printer the ink cartridge jet holes line up with? Plus after doing so insuring that both areas were dry?
You may have ink dried up in those tiny jet holes. A hairdryer set to low heat, and constantly moving back, and forth when using it to dry these areas, helps too.
(After using the Isopropyl alcohol method. Use CAUTION as Isopropyl alcohol is Flammable!
I know, DUH! But it has to be stated.
I use a clean, lint-free cloth, and warm water. Wring the warm water out until the cloth is just lightly damp. BE SURE those above mentioned areas are dry, before reinstalling the ink cartridges!)
3.MFC-3240C off, and unplugged?
(Opening the cover, and closing it helps to remove error codes, as it will reset itself. Unplugging from power, replugging in, and turning on does also. You may still have the error code of unable to clean, because it hasn't be cleared)
Aug 17, 2009 | Brother MFC-3240C All-In-One InkJet...
It prints everything but black
1) Try cleaning the printheads as outlined in your manual.
2) Replace black ink.
May be a clogged nozzle.
Go through the printhead cleaning at least twice.
Jul 28, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer is''Unable to clean''
hey, Your Cartridge is blocked by ink.
so you can replace your cartridge or another way same printer cartrige install and check it
Fame !
Jun 05, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean message
Remove the ink, turn off the printer. restart the printer then reinstall the ink
Nov 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-215c unable to clean?
There is no Error 10 within the maintenance of the printer!
An error starting with 10 (and two more digits) belongs to the communication device (fax).
Plz check again what two digit error you have and post again.
you need a new waist ink absorber. plz check the forum for unable to clean or error 46. Its explained many times.
Mar 27, 2008 | Brother Multi-Function Center® MFC-215C...
Brother MFC 210C All-In-One InkJet Printer Logo
94 people viewed this question
James Cagle
James Cagle
Jim Keysor
