Question about Garmin Nuvi 350 Car GPS Receiver
A picture of a computer appear on the screen
I have a problem ,when i plug my garmin 350 with my charger or my usb cable on a computer a computer with a screen appear on the screen of my GPS
    Top Expert:
  • Garmin Master
  • 76,846 Answers
The USB port is defective
Posted on Jun 04, 2010
Shut off
You should only see the computer icon when plugging the 350 into a USB port on the PC. If you see it when plugging in a car charger/adapter, then there may be a problem with the mini-USB port on the 350 or the charger is an after-market charger that is not electrically compatible with a Garmin charger. Please see this link for more info:
http://www.sharc.net/gps_charger_repair.htm
May 29, 2013 | Garmin Nuvi 350 Car GPS Receiver
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
Nuvi 350 will not run on DC charger
Make sure your DC & AC charger is a OEM charger.
There is a good chance that there is a bad connection on the mini-USB port.
What happens when you plug the unit into the cradle and NOT use the mini-USB jack?
- Jim
SHARCNET-USA
Apr 19, 2010 | Garmin nuvi 350 GPS Receiver
I cannot use the GPS unit while in charge mode(NUVI 350)
Are you using a USB cable & charger to operate the GPS?
If so, you should stop and use the supplied cradle / power cord to power the GPS instead. The USB cable is used to transfer data to and from the GPS and on other models (maybe your 350, too) to slow charge the GPS battery when completely discharged. Powering with the USB cable will power up the GPS, but does not allow navigation, mapping, etc.
Oct 12, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Jun 08, 2009 | Garmin nuvi 200W GPS
Cant use the garmin 350 while charging
The solution is really easy. Works in the car or usb charger or whatever.
Once you insert the car charger, wait till the pc connection picture comes.
Than unplug the car charger.
Re-insert it as soon as the picture goes off.
Voila. It is ready to use now!
Feb 08, 2009 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
Problem with Garmin Nuvi 200
hold the battery icon for 8 seconds, which will take you to the test screen then plug in the charger then exit This works on a nuvi 200w.
Aug 15, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 350 with Ver: 5.30 software
From your description this sounds like normal functioning unless I am missing something. When the unit is connected with the USB cable to a computer, it will appear as a storage device (i.e. disk drive) to the computer. I.e. Open 'My computer' and you should see it in the list of devices as another disk drive such as E: or F: or whatever the next available drive letter is on your computer. Now open the drive letter and you will see the files in the NUVI. On mine I see the user's manual as a .pdf (Adobe) file. I don't have explanantions of what the other files contain, but I believe in the user's manual there are explanations for at least some of the files. One or more contain user data and this gives you a way to back up this information so that if you perform a software upgrade that erases all this data, you can re-load it into the Garmin when you are done with the upgrade. You can copy any of these files to your computer by doing a typical file copy operation. I would be careful not to delete any files unless you know what you are doing. I believe deleting some files may cause the Garmin to stop operating, but I'm not sure.
Mar 23, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 360 power problem
You'll need to open the case and replace the battery. Batteries can be purchased online here or a couple other places on the web by searching for "nuvi 360 replacement battery". I'd get the 1400mah or greater for a replacement, it'll burn a little longer than the weaker models. If the unit operates when plugged into the charger, then the fuse and cable are good. Open the case by removing the retaining screws, then carefully prying the unit apart. The new battery simply plugs into the connector after removing the old one.
Nov 13, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
179 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
