Question about Maytag MHWE300VW Washer
Maytag front loading model MHWE 300VW12 bought from Sears in Oct 09. Spin cycle is like a jet plane taking off. You can hear it all over the house. Even shutting the utility room door isn't effective. Any idea what's going on?
  • Maytag Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Jun 05, 2010
I have an older maytag front loader washing machine, during the spin cycle, it sounds like a jet engine taking off, need help with repair
Step#1 go to 'Sears Parts' find your make & model. This will provide you with a complete diagram. Problem sounds like #1 drum support rollers #2 drum seal rings #3 drum drive belt or #4 the drum drive motor or its spring supports. Open the machine housing were you will see inside Ops during noise will ID the problems location. CAUTION!!! Electricity can KILL & Mechanics will take a finger or arm with no questions asked. "You feelin lucky punk"
Apr 21, 2016 | Maytag Washing Machines
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
Maytag MHWE 400ww bought 11/08/11. It sounds like a jet fighter when in spin mode, so loud you can hear it outside of house, sounds like a possible dry bearing ( I have millwright experiance) cannot find...
I had a very similiar problem with my new washer about a year ago. I finally adjusted the legs on it, to get it completely level, and it stopped sounding like a jet fighter. It wasn't off by much, in fact, it was so close to being level, I didn't think it was worth adjusting.
Aug 11, 2013 | Maytag MHWE400WW Front Load Washer
During spin cycle washer is making loud noise
If it is making a sound like a loud rumbling sound similar to a jet plane taking off, it probally due to the seal has failed causing water to leak into the bearings. The bearings begin to rust, and no longer round and the noise gets progressively louder. It can be rather expensive to fix. Get a few estimates before deciding whether it is worth fixing.
Aug 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
Sounds like the inside is a jet plane while in spin cycle very lose inside like something is loose ore broken like a belt
If the washer is vibrating a lot, then you could have a bad drum bearing. There are also counter weights and shock absorbers that could be bad. The best thing to do is take off the back panel and look inside. many times the problem can be clearly seen. Usually a loud noise like a jet plane on spin cycle means a bad bearing. This can be costly unless you can do the work yourself. The parts are readily available.
May 26, 2010 | LG WM-1832C Front Load Washer
Maytag Epic front load washer spin cycle sounds like an airplane is taking off
If you mean a jet aircraft, that is normal. Front loaders achieve amazing spin rates.
Feb 14, 2010 | Maytag MAH2400A Front Load Washer
Noisy during spin cycle, sounds like a jet plane at full spin.
the drum bearings have gone, expensive repair, this is caused by over loading the machine
Feb 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Model FWT449GFS1 Frigidaire Gallery problems: roaring during spin cycle, worsening drum won't turn manually and this last run, was making sounds like slipping belt. During drain time, can hear coin in...
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Sep 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Still wet clothes
It sounds like the high speed of your motor is not functioning which tells me it is either burnt and needs to be replaced, or that the control dial is malfunctioning. Because those motors have two or three speeds, usually one of the speeds of the motor is malfunctioning. Always check connections too, and see if it functions in the spin on another cycle. Best of luck. C
Mar 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MHWE300VW Washer Logo
269 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
