It simply stopped. The box outside is switched on.
    Scholar:
  • 45 Answers
I am going to assume you are talking about the outside condenser. If the thermostat is calling for heat and the furnace blower is on, you may want to check the capacitor inside the outside unit. Disconnect the power to the outdoor unit and open up the electrical compartment. There is either a round or oval silver cylinder inside by the contactor. That is the capacitor. If the top is buldged it is a true sign of a capacitor failure. Remove the cap and take to your local HVAC Wholsaler or contractor to have them replace it. It is a very common part and should cost you around 15 to 25 dollars. Let me know if this helps.
Posted on Jun 05, 2010
How do i stop it from rebooting
Follow these steps to solve your problem
-Go to Start
-open the Control Panel
-Select Performance and Maintenance
-Click System
-Click on the Advanced Tab
-Click Settings in the Startup and Recovery section
-Uncheck Automatically Restart in the System failure section
May be it happens due to hardware issue
-first you should Change the CMOS battery on your motherboard
-Clean the motherboard, Cable Slots of Hard disk, RAM Slots, CD Drive Slot etc inside the CPU box
-Attach one more fan inside the box to exhaust the hot air from inside the box to outside
If this solution doesn't work then follow these instructions simply get the Reginout to fix all the registry issues which made this annoying problem
Jul 01, 2013 | Computers & Internet
My rogers hd box the picture keeps flickering i've tried to reboot but it does not fix the problem
Have you tried a signal booster, i really do think that will help. Your reception can be to do with a few thing's, i.e. Position of your tv, Faulty receiver on your main (outside) aerial, A breakage or fault with the aerial cable coming from outside aerial to tv, or your outside aerial can just simply have a bad signal.
Oct 14, 2010 | Televison & Video
Have a tork time switch (mechanical) and have question on how to ground it? Also help in understanding their wiring diagram on box cover..
They are simply grounded by a screw inside usually on the metal box... it will be identified by its green color...simply connect the ground wire to that green screw...
L1 will be the black or "hot" wire and L2 or N will be the white wire...
L1 will feed through and be the "hot" coming out switched...normally open is when the switch needs to make to send power out and normally closed means that when the switch makes it will stop the power going out...
heatman101
Aug 07, 2010 | Hardware & Accessories
Rear wipers do not stop to the switch
check the relay under the switch arm! sometimes situated in the fuse box as well, common problems with these cars, simply buy a replacment wiper arm and fi!
Hope this helps
Oct 28, 2009 | 2000 Renault 181
C1900 without waste box
I don't know anything about this printer but look for a small switch where the waste box attaches to the printer. When you locate it press it in and if the "install waste box" goes out you simply have to devise some way to keep the switch pressed all the time. Try some super glue, or maybe a simple piece of paper folded up. Good luck.
Jul 22, 2009 | Epson AcuLaser C1900 Printer
Reverse lights not working on 94 jetta
The switch is located on the outside of the transmission. You'll see near the side of the transmission. There should be 2 plugs. One has an allen screw holding it down located right by the inner cv boot (this is the speedometer drive) To the left on a raised portion will be another plug with what looks like a nut or bolt head attatched to the bottom (this is the reverse switch) To remove it simply unplug the connector and remove the switch using a box end wrench.
Feb 08, 2009 | 1994 Volkswagen Jetta
Water won't stop filling
Kenmore pressure switches are generally adjustable, the spring inside stretches over time, there is an adjustment screw or nut, clockwise raise, anticlockwise lower, water level.
  • test of the pressure switch outside of operation is difficult and indecisive,
  • switch will still throw when you blow in it,
  • a foot of water height difference is only 0.4psi so a fractional misadjustment of the switch out of the box, or the internal spring stretching just a little, and the water runs over.
Not a solution sorry, something to check for
Jun 18, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
